Genoa T Track, to curve or not to curve?
Sep 8, 2014
2,551
I got some new Ronstan 1 inch T track for my new Genoa Cars to mount inboard tracks on my Catalina 22. The track is 39 inches, just a bit shy of the original 48 inch tracks mounted outboard (you can see the epoxy filled holes in the pic).
I want to get my mounting sorted before I paint everything and apply nonskid. Under the track will be masked off so there will be no nonskid under any deck hardware, just the gloss white SP paint. All holes for deck hardware have been epoxy potted and counter bored lightly.
Anyway... I'm thinking I should curve the tracks when I install them. I am only slightly worried about the car traveling smoothly after its curved. Looking for any words wisdom before I ruin a $50 track, lol. The plan is to mount the track as tight to the cabin as possible, leaving 1/16" to 1/8" clearance beyond the car body. I don't think I will be putting any track back on the outboard toe-rails. I'm also leaving the life-line stanchions off.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
It doesn't appear to me that from your photo at least, there is all that much of a curve to be concerned about. There are a lot of boats that utilize curved tracks.
You could possibly experiment by setting the new track up on a piece of scrap plywood wit just 3 or 4 screws to duplicate the curve. Then slid the car on it to see if it binds. Consider also the side loading when in actual use
Jul 14, 2015
840
Catalina 30 Stillhouse Hollow Marina
Not even a hint of binding here. These are curve a lot more than you would need to.
-na -NA Anywhere USA
Cloud Diver;
As a former Catalina dealer, I installed genoa tracks and cars in the same area that were slightly curved. The loading was not different nor did the cars bind. I would tend to wonder where the track in placed in the photo that the turning block would hit against the cabin coach side or not thus marring the finish when under use.
Nov 8, 2010
11,386
The trick is, some track/car systems are DESIGNED to curve.
Nov 8, 2010
11,386
Agreed. Also make sure you have fair run from the sail to the car and from the car to the winch in all car and clew positions.
Gunni
Mar 16, 2010
5,937
My track is OEM straight and close to the cabin top, making it possible to sheet in the Genoa very close.
Jan 6, 2010
1,519
Cloud,
I don't see a radius angle so, a straight track should work in your setup with no problems.
John, I have a 1980 Mark II very similar to your cabin design. When I redid my deck, I did not want to use the toerail t-track for my ginney.
I installed a new t-track along the curvature of my cabin & have NOT had a problem with adjusting my cars.
I do find a better inboard angle for sailsets & all has been well the past 3 years.
My one suggestion is adding proper backing plates below to take up the added strain.
However, it's quite easy to slightly curve your ginney track.
CR
Oct 24, 2010
2,405
Hunter 30 Everett, WA
My tracks were straight when I removed them to rebed. No problem springing them a bit to reinstall.
Ken
Ted
Jan 26, 2005
1,280
You probably won't have a problem but check with the car/track manufacturer. I know for a fact that Harken has a specific minimum track radius that their cars can run on without binding. My bend it tighter than that with a Harken system and no problems.
Jul 14, 2015
840
Cloud,
CR
Captron, do you use this new track for anything bigger than a 100. I have a 130.
Jan 6, 2010
1,519
John,
I run a 155 ginney. What I did do was to make sure I have great support below.
The other advantage with the deck & inner liner molds, fiberglass & all materials are stronger structurally near angled bends. The secret then is, really in the backing support.
CR
Jul 14, 2015
840
John,
CR
If you get a chance, post a photo along with one of your run back to the winch
Bob J.
Apr 14, 2009
775
Sabre 28 NH
Just wondering, why are you going with a shorter track & relocating inboard? I don't know anything about your Catalina but the holes that are filled with epoxy, isn't this part of your deck to hull flange connection? If so why would you want to drill additional holes thru the deck to accommodate the new T track?
FWIW, I do things to my boat that people don't understand but seems to make sense to me :)
Jan 6, 2010
1,519
John,
The only pic I have was when I re-did my deck.
As you can see, the track was offset enough to not impede my car.
Note the changed color format not found on other Cat 30' Mk II.
CR
2,551
The shorter track (by 9 inches) does not effect anything. The old 48 track on the toe rail goes all the way back practically to the base of the winch. You wouldn't move the car that far back even flying a 150 genoa, even if you did you'd no longer have a fair lead to the winch. When using the shorter track you align the front of the track to the original position giving you plenty of car positions to handle the 110 Jib and move back for the 130 and 150.
The inboard genoa track is a popular upgrade for Catalina 22's, sheet in tighter to point slightly higher. The old mounting holes through the toe-rail and the new mounting holes have no effect of the hull-deck joint. The new positions are actually much easier to get to with a wrench.
Jan 6, 2010
1,519
Mis,
My orig. track was at the toerail. I did not get the right sail shape with the track outboard.
It seemed that my 155 had a flatter rear sail shape & knot an aerodynamic shape throughout. Just look at the newer designed boats & where their tracks are set. That's what gave me the idea.
The only new holes I made are sealed & supported well. I left my toe rail track in place. Maybe at some point, I may have to use the orig. track, who knows?
Remember, sailing is nothing different than flying a plane sideways.
The same laws of physics come into play. The only difference is adding water induced friction.
Now I can get a much better foil shape going close-hauled & I still have enough length of track for all points of sail.
But, how bout my modified paint job?
CR
Nov 8, 2010
11,386
John,
I think Ron, that John's question is exactly what your track shows; that is your car is shown in the only position that makes a fair run to the winch. Without a turning block to help, the rest of the track is unusable. It looks like you might have one, but out of the picture.... where does the sheet go?
Jul 14, 2015
840
John,
CR
Also Ron, you said your boat was a 1980 MK II. They didn't change from MK I to MK II until 1986. Even though mine is a 1986, it was built in October 1985 and still of the MK II design. MK II has two large windows, and 2 small each side, vs the 3 large and 1 small on the MK I. Also the MK II had t shaped cockpit at the rear. Am I missing something?
Jan 6, 2010
1,519
John,
The paperwork I have states a Mark II. Not a big difference from Mark I. The design is close.
Jack good question pal,
My turning blocks are now aft the winches & located on the rear of the toerail track. The beauty is that the line from the cars runs close inboard along the cockpit coming sides then angles to the turning blocks back forward to the winch. When stepping out of the cockpit now to go forward, there is no angled line to my winch that interferes. My orig. line went from the car & angled to the winch which was not good for leaving the cockpit for deck work. But that was the orig. setup.
Catalina 30's have a narrow deck for going forward especially stepping out of the cockpit. Now, I don't have to deal with stepping over an angled sheet. I have a double winch setup on my cockpit coming top, one for the ginney & one for the staysail. My spinnaker track is on top of my cabin. I just found that this t-track relocation was a better way for giving better access forward & not having trip points mostly for guests.
Using car marks from my orig. toerail track, I positioned the inboard track parallel to the toerail track for adjusting the t-track length to work with my cars @ different points of sail. My tracks are 6 ft. long & I've been very happy with the positioning & the length.
Stepping out of a Cat. 30 cockpit, you only have about 10" of foot room. That's not that much especially on a heel or in spirited conditions.
CR
