Last summer, we had a new shaft, coupling (split coupling), and cutless bearing installed on our Seaward 25 (yanmar 1gm10 motor). It was a vacation saving repair. I ran for the parts, who were made up for me at a marine machine shop, and had a local marine mechanic do the work. When he did the motor alignment, he told me he was able to get the top and bottom of the coupling within tolerance, but was only able to get it side to side within .023". He told me there was no adjustment slots on the mounts, and suggested I remove them and slot the mounting holes and readjust when I got the chance.
After we returned from our trip, I took another look at the mounts and noticed one hole on each mount was slotted, allowing you to twist the motor some for adjustment. I was able to get the motor adjusted to within .004" top and bottom, side to side. The motor has never been so smooth since the work, and I didn't really notice much difference (if any) since I readjusted things. I also moved the the shaft anode closer to the strut as I noticed he had it quite far away. This actually helped smooth it out even more.
When I pulled the boat this fall, I noticed the shaft was not centered in the stern tube, and was very close to the port side of the stern tube (see 1st pic. below).
I replaced the PSS seal (something we didn't get a chance to do this summer), and realigned things on the trailer. With the shaft centered in the in the stern tube, I was again fine top to bottom, but had about a .023" gap on the starboard side of the coupling. So I decided to try for a compromise...a mostly centered shaft and close as I could get with the feeler gauges. Due to clearance issues, I can't get the front of the motor any more over to the starboard side, and moving the rear of the motor to port pushes the shaft further out of being centered in the stern tube. About the best I could get the gap down to was .014" on the starboard side of the coupling. See 2nd pic below to see the view of the back of the stern tube.
There is no indication of any problems with the strut. Eyeballing it with a square shows no signs of it being bent (or loose). I'm assuming, the boat was probably this way when it was manufactured?? The last 2 pics. are looking aft at the cutless bearing. The prop shaft seems to be pretty well centered there. If anything, centering the shaft in the stern tube would even make the fit better at the cutless bearing. Of course, this is opposite to what would improve the fit at the coupling with the feeler gauges.
So...I'm tempted to just call it close enough, but is there anything else I should try?
