Mine is the same, but should I hook to battery or switch?If you set the switch to "ALL" yes. On our switch we also have an Off that disconnects everything. Nice when working in the DC fuse panel. I have our solar panel hooked to the distribution side of the switch, it allows us select which battery bank is charging, we usually leave is set to "ALL".
@JohnVTX, do what Stu says...Read the info and figure out what you have first.
I re-wired my boat to one of the non-factory recommended ways described in some of the info Stu gave you and now I don't worry about anything anymore (well, not anything, just not my battery charging).
Here's a basic diagram of pretty much what I have now. So, MY switch doesn't matter what position it's in anymore. It's always charging both batteries by the engine or AC charger, and I now use position 1 as the "main" battery and only switch to #2 (reserve) if I drained the first one by accident. I also upgraded my battery wiring to 1/0 size and engine starting is very happy.
Stu, no need for any credit. If you like it, take it! PM sent too.jon,
That is a SUPERB wiring diagram. It makes the main basic connections very easy to read. Would you mind if I "pirated" it and included it in my oft-linked battery wiring diagram thread on our C34 website? Of course, I'd use proper attributions. Would you send me the original jpg so I can post it there?
Thanks,
Stu
That sounds weird.guys. slow down. among other things catalina itself changed the wiring. by the time my boat was made in '91 the master switch kept the batteries live even when the switch was turned to 'off'. it is clealy so placarded.
