Lead will oxidize like any metal will. There are types of metal oxidation that you can't even see with the naked eye. The scale you see is most likely produced by a combination of the lead an other metals present in the alloy like antimony. Other trace metals can be included like tin or copper to increase hardness or reduce metal fatigue, but who knows. It is doubtful that you really need worry about removing the scale completely, just sand with 80 grit to level out the surface and remove any stubborn flakes the blasting missed, the sand blasting should already have given you a nice grippy substrate for the barrier coat. The Interprotect is very good at filling to a degree, but fairing all the tiny pocks with the epoxy filler will do most of the work. There is a good deal of argument out there about how to fair the hull to keel joint, it usually depends on the type of keel. Since you have a keel stub that connects to the lead keel 1/3rd down from the hull you shouldn't have to worry about flex there so fairing with the epoxy filler is just fine, a flexible epoxy like G-flex or 'softer' adhesive Sika shouldn't be needed.
