GPS Madness
Webone
Apr 30, 2010
50
Jeanneau 45.2 Saugatuck, MI
I am getting ready to install a SSB radio and of course it needs a GPS antenna, so now I have one for the chartplotter, one for the vhf radio, and another for the AIS. The back rail is looking like a mushroom farm. Is there some way to reduce the number of antenna needed with out too much expense?
Jan 4, 2010
1,037
Farr 30 San Francisco
well if the stuff is networked your electronics should be able to pull it off the network. AIS B is the exception, as I understand it there is a requirement for its own antenna.
Failing that you can get chart plotter with integrated GPS, you can get VHF with integrated GPS ...
Nov 8, 2010
11,386
John is totally correct. For NMEA2k networks (with the exception of AIS-B transceivers), networked devices can be programmed to use any network GPS source. Often this can be the GPS chip IN THE PLOTTER.
If your kit is NMEA0183 you have another set of problems.
5,274
GPS works in the cabin. Mine is on the inside top of the coach roof and I have just a wee bit of signal loss. Also, I have a Garmin handheld GPS besides my VHF. The Garmin has an internal antenna, still no problems. So just try putting your rigs GPS near the rig.
Apr 11, 2010
992
Hunter 38 Whitehall MI
Not quite true on AIS B requiring its own antenna. I do have a dedicated antenna located on the Bimini frame for my AIS but friends have a splitter that allows the AIS and VHF to use the VHF antenna located at the mast head.
Using that antenna he gets an amazing range often 60 to 100 miles
Mar 12, 2008
557
Jeanneau 49 DS San Pedro, CA
Which radio are you installing, the ICOM 802? If so, you don't need an antenna, you just need the NMEA signal in. If you have a chartplotter with an NMEA 0182 output, you can run this to the radio. I have one NMEA out on my E120 Raymarine charetplotter, which I use to feed the VHF, SSB and Pactor modem.
Nov 8, 2010
11,386
I'm pretty sure that AIS-B TRANSCEIVER (receive AND send) need to have a dedicated GPS input. This is a fail-safe designed to keep the unit functional at all times.
Webone
Apr 30, 2010
50
SSB is an 802, however plotter is a Raymarine E80 classic so no NMEA 2000 only 0183 and seatalk. SSB needs GPS for DCS system location.
Jan 4, 2010
1,037
AIS B needs its own GPS mushroom, you can have a splitter and share the boats masthead VHF
Apr 11, 2010
992
Actually I have one GPS mushroom and it is connected to a Digital Yachts AIS transciever, a wifi unit and to my VHF radio. So one antenna is serving AIS, the VHF and through wifi it connects to inabx on my iPad.
Jan 4, 2010
1,037
Quad Thanks for the tip, acc Digital yachts site the unit "has its own internal GPS receiver" So we are both kinda right. Looks like better value than the RM unit I have at $800 +
Apr 11, 2010
992
Might be a different model than what I have because my GPS is external but same concept. Perhaps a next Gen product.
Digital Yacht has great products at reasonable price comparatively.
May 24, 2004
7,213
CC 30 South Florida
Yes, you may not want to advertise to potential crooks that you have multiple, valuable electronics.
Jan 4, 2010
1,037
Well I admire a good crook. If someone took the time to read this forum, track down the boat, defeat the marina security and grab my hopefully insured stuff well not exactly more power to him but an admirable amount of effort nonetheless. Beats bashing me over the head and taking my wallet.
