I read you paint application spec. At no time did they use this mixture.I just put the garden lime in the PVC bucket, add water with stirring... then add the KOH... about two to three cups worth. Probably could just dump two cans of drain-o....I don't think it matters what you use to keep the paste moist. I have even let it dry without a cloth and just re-wet it with a light mist using the "thumb over hose end" approach a few times before blasting it off. And I have used plastic sheeting and once an old tarp. I think the commercial stuff uses sheets of wax paper.... so maybe an old news paper would work also. The nice think about burlap is that it strains the mess when you blast it off... so you can catch all of this toxic paint for proper disposal.
Listen to Maine Sail...Merely scuffing the paint is often not enough when switching paint types. The directions needs to be followed to a tee..
Sorry there is not an easy way to recover/renew that bottom.
Jim...
