OK, 2 wks ago found batteries dead after charging the day before.
Read all I could on forum about battery replacement. Purchased 2 group 31 Duracell wet cell deep cycle batteries from Sam's. Pulled old gp 24 WM starting batteries, wrapping cables together and labeled as they were removed from terminals.
Reconnected new batteries/cables. Tried to start, barely fired, but ran about 5 seconds. Terrible screeching from belts! Checked voltage on batteries, found 12.5 on one, 12.3 on other. Tried to start again & not enough charge to start. Disconnected Battery 2 & left - will return tomorrow with charger.
Questions:
1. Shouldn't batteries be fully charged from store? Is this a beginning of battery problems from the beginning?
2. Why all the screeching from belts? Never had this problem before even with motor sitting for long time between starts.
Cables reconnected to correct terminals on correct battery. But could diesel be trying to run backwards?
Questions:
