There are times when instead of writing out certain words, we might want to use special characters. As an example, instead of saying "today's temperature will be 50 degrees", why not just use 50°? Whoa... where did I get that ° symbol?
And, for you electrician guys talking about ohm or impedance, you can use Ω instead of spelling out ohms.
There is a table called the ASCII Character map which assigns numeric value to special characters. As an example...
ALT+248 will equal °
ALT+234 will equal Ω
Now this is on a PC keyboard. I do not know what the Mac version would be. Maybe someone who has a Mac can answer.
Give it a try in the reply box. No need to post unless you want to show your new found skills. The WYSIWYG format of this and many other forums will let you see what will be posted before you post.
Here is a link to the one of the many ASCII tables available. One should take note that not every special character will be usable. It depends on your machine and which ASCII table is embedded in your firmware.
Have fun!
Have fun!
