No more wobbly rudder
Doug J
May 2, 2005
1,192
Hunter 26 Oceanside, CA
I just finished re-furbishing the rudder assembly on my H26, which was in horrible condition. There were missing parts, and the parts that were there were very badly worn. The tiller was extremely sloppy. I bought parts needed from SBO store, Al was very helpful explaining what parts were needed.
Item# 827493 Tiller Stop Bushing
Item# 827492 Rudder Pivot Bushing
Item# 827491 Rudder Friction Bolt Bushing
Item# 800523 Rudder Spacers
Item# 827352 Rudder Spacer Gasket
I re-used the Gudgeon Blocks and the aluminum plates. The plates are very badly corroded from salt water, but will still work. I cleaned them up real good, applied primer and top coat of paint, should be ok. I used 3M 90 High Strength spray contact adhesive, to glue the rubber spacer gaskets to the plates. Time will tell if it lasts, but the adhesion seems to be very good.
All nuts/bolts have been replaced with new stainless steel. The end result is a real solid feel, I assume like new. Anyone with the same problem, I would highly recommend replacing all the parts, it's an easy job and can be done easily in a couple hours, once you have all the parts and supplies ready to go.
2015-11-28 11.42.42.jpg 2015-11-28 11.45.07.jpg 2015-11-28 12.19.46.jpg 2015-11-29 07.56.12.jpg 2015-11-29 07.56.41.jpg 2015-11-29 07.57.18.jpg 2015-11-27 09.42.34.jpg 54823.jpg
115
Hunter 26 MN
View attachment 117650 View attachment 117651 View attachment 117652 View attachment 117653 View attachment 117654 View attachment 117655 View attachment 117656 View attachment 117657
Nice! I did the same, but didn't paint my aluminum side plates. Yours looks great - I think I'll take everything apart and do that as well.
I completely agree - it's a very easy job - well worth the time and minimal expense to keep your aluminum tiller from getting damaged.
Wow thanks for posting the pics and part numbers. I have only had my H26 for a month... have not taken it out of the water yet.... but this week I was sailing her a lot and I noticed a rubber-ish looking grey bushing thingy floating away behind my boat. And then I noticed the rudder started to wobble side-to-side. So I'll be doing this same job and now I have all the part numbers.
THANKS AGAIN!!!!
