Cockpit lighting at dock
May 28, 2015
280
Catalina 385 Atlantic Highlands, NJ
Searching for Ideas for cockpit lighting while dockside. With DST turning to EST it gets dark really early and my phone/flashlight didn't do the job well last night while packing up. First time I have to admit I miss something from my motor yacht's features ... The cabin top cockpit lights.
Kermit
Jul 31, 2010
5,722
Great idea for a thread. I'm replying partly to let you know I like your thread and partly to be automatically subscribed. I hope those that have experience will chime in. I have an idea on a related subject but will probably start a new thread so as not to hijack this one.
Mar 28, 2014
49
Catalina 30 Hyde Park NY
I have a set of solar powered LED lights, they work very well if receiving sufficient sunlight.
From amazon a set of four for $40.
Jan 9, 2011
21
C&C 26 Solomans
Slipped in a 'rod' holder, they work great, replacements can be had at 'wally world' also.
7,689
Alden 50 Sarasota, Florida
Lots of people use string LED lights wound around the dodger bow(s) run discretely to a convenient 120v power source. Makes a wide light source to light the entire area rather than discrete spot lights.
If you're locking up the boat, then most of us turn everything off, right? So you don't want something either 12V or 120V because you'd need to turn it off before you put the last hatchboard in.
Find either a solar light with an I/O switch or a small battery powered LED puck light to use for those last few minutes.
Nov 6, 2006
10,212
We just found these and bought one just to see..
http://www.amazon.com/MPOWERD-Outdo...TF8&qid=1446397350&sr=8-2&keywords=luci+light
It makes a fine cockpit lamp . Has bails to hang it from bimini frame puts out plenty light.. deflates to almost no size. has high and low power settings.. would be fine as an anchor light as well if positioned correctly.. downside is ya have to take it from under the bimini and put it in the sun to recharge..
capta
Jun 4, 2009
5,072
Spreader lights will have multiple uses including lighting the cockpit and boarding areas. If you get the LED ones they draw nearly no juice at all.
Mar 20, 2012
3,983
my boat already had LED "courtesy" lights in the footwell of the cockpit, wired to a switch in the cabin... this worked well for when at anchor and we wanted a bit of light in the late evenings, but it didnt work for when we were either locking up or unlocking the boat in the dark when we were arriving or leaving because we have a combination lock on the hatch....
so I got two more of the courtesy lights and mounted them on either side of the companionway, then wired them on a weatherproof "momentary" push button switch, mounted outside near the top of the cabin bulkhead. now i can just hold the button in and get all the lights to come on... I can then unlock the hatch to get in and turn on the main switch.
the momentary push button prevents forgetting to shut them off when you leave, but allows you to always have the lights immediately available when you are in the cockpit.
Gdindy
Jul 11, 2007
44
Hunter 410 Washington Park Marina, Michigan City, Indiana
We received two of these as boat gifts for our sailboat. They have worked great the last two years and still going strong. They move with the motion of the boat, like the old weighted punching bags when they do move they return to the upright position. If you turn the switch to off, and charge for most of the day in sun, you will get just about all night lumination from them. Hard to find originally purchased at Ikea, but cannot find on their site any longer but did dig them out of the winter storage to find name, eBay is only place I can find them now. Enjoy!
http://www.ebay.com/itm/Solar-Power...ed-Blu-/171262995568?var=&hash=item27e011ec70
Nov 8, 2007
1,613
Usually plenty of ambient light in a marina, or from the night sky when we are at anchor (our favorite destination.)
If there is not, we used an LED head lamp. They are great, throwing the light right where I am looking. For back-up, we have a 12v 360 degree LED we could, (but never have) use.
Beneteau 323 Annapolis MD
Several thoughts...
Lowes sometimes has a Japanese paper lantern the collapses flat, and can charge that way- or hanging -via a solar cell on the top. Nice mood light! Less than ten bucks.
I just saw at Home Depot, lids for mason jars that you supply your own jar, fill with whatever suits you. Solar panel in the lid, light underneath. $4.99 as i recall.
Or, as Robert Reford did, start a fire in a dishpan.
2,809
Ericson 29 Southport..
Several thoughts...
Too bad it wasn't a biography. Stupidest $hit I've ever seen.
(It's why I chose my avatar)..
Likes: Windtherapy
May 28, 2009
764
Hunter 376 Pensacola, FL
Solar garden lights are the best bang for the buck. Don't buy the $1.99 ones at WalMart-they just don't hold up as well as the ones in the $5 to $6 dollar range sold at Lowe's and Home Depot. The solar cells and LEDs last for years, you'll want to put in a new rechargeable battery every year or so if you want the lights to stay lit all night. The best thing about them (for our boat, at least) is that when you pop the lights off the ground stakes, the stub on the bottom of the light fits perfectly in the handle hole in the top of winches.We keep lights sitting in two or three of our winches, and they've stayed put through 50 knot winds. Here's a picture that captures one on Eagle Too.
HMT2
Mar 20, 2014
900
Hunter 31 828 Shoreacres, TX
I second the Luci light. I hang it from Bimini with a small line or place it on the cockpit table. I even use it as a work light in tight and dark spaces. It holds it's charge for a long time as well.
136
hunter 380 Plano, TX
I love mine but have the arch that came with a couple 12v halogen. I have replaced the bulbs with 10-30v red LED. Make sure you get a voltage spread and not just 12v because you will burn them with your charger otherwise. Get some surface mount mini pucks and mount under your bimini. Go fancy and route the wires in your tubing and if you use these you could even have an on/off dimmer which you will love for night sailing as the red will not destroy your night vision. They are only a couple watts max and we leave them burning on the hook at night. They are tied into one of the courtesy light circuits. We use ours constantly. Goodluck
