Hello all I am new to Catalina and this Forum. We are looking to purchase a 1988 C30 and just had the survey done yesterday. The issues that was noted starting from what I feel is the largest to the least is as follows:
1. Motor mount front Starboard needs replaced. (for now the engine seems to be in alignment but the mount is shot.
2. Exhaust elbow into the muffler is not leaking but is in need of replacement.
3. Sails are original but usable. 3 head sails.
4. The pulley on the head sail at the top of the mast seems to be draging. Hard to put up the front head sail.
5. slight leak on the sea water pump seal. Probably cause issues with motor mount.
6. Seals around the head . Told just to replace the head.
7. Auto Pilot works but seems to hunt rather than hold a straight course.
8. Old electronics
9. Insulation around motor is trashed.
The good of the boat.
1. Great new canvas covers, Heating and cooling installed. New batteries, New running Rig, Motor runs great universal M25, The boat seems to be very well cared for. Clean, lots of extras, The Hull and bottom very good condition. Wing keel 3'10 draft. Great looking boat in general. No window leaks. no wet spots found anywhere. Two blade prob spins freely with not a lot of back lash.
Question how hard / expensive is it to do motor mounts and exhaust elbows? Thanks for any advice you can give me as I have not committed to the purchase yet although we really do like the boat.
8. Old electronics
