Boat Stands?
pateco
Aug 12, 2014
2,207
Looking to haul my 1983 H31 Shoal Draft in the next couple of weeks. This is the first time I have hauled it since I brought it down from MD.
I can rent stands at the yard I am using, but I can also buy stands for a decent price.
Used Secondhand Boat Stands CHEAP!! - $55 (Ft. Lauderdale)
What size should I buy? They have 3', 4', and 6' available, and how many?
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
get 1 -3 ft for the bow with a v shaped screw and 6- 4 ft for the rest of the boat and get some chain to tie them together
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
then you may need to go all 3 ft and a 2 ft under the bow...how deep is the draft from water line to bottom of keel
Jun 24, 2014
74
Kayaks for now, oday coming soon 13 Waterford, CT
It appears they don't have 2 ftrs.
That's too bad really, you are going to have to get large blocks to go under the keel.
I have adjustable boat stands, they go from 29 to 59 inches. Maybe you can find some of those on cragslist. I picked up a set of 5 (1 bow V) for $50 each off of craigslist.
Jun 24, 2014
74
Which reminds me. Don't forget to get two blocks to rest the keel on.
May 24, 2004
7,179
CC 30 South Florida
Are you storing the boat? If just hauling out for a few days for repairs just rent the stands.
pateco
Aug 12, 2014
2,207
Just hauling for a couple of weeks to do Cutlass bearing, check all thru hulls, sand, buff, and polish hull and deck. I may also replace the rubber boot on the packing gland. depending on how easy the Cutlass bearing goes.
She draws 4.5 feet
Scott
Sep 24, 1997
242
Hunter 31_83-87 Middle River, Md
We use 6 S-1 stands. Don't know the size range but is fine for an 86 h-31 (shoal keel)
623
Hunter 31_83-87 New Orleans
i had 8 total on my last haul out for painting, 4 each side for the deep draft. also as stated above, need chain to connect to stands and blocks under the keel
