How do I repair/reset fittings on Hunter 140?
I just bought a Hunter 140 and the gudgeon plate needs to be remounted to the transom as well as a cam cleat on the stbd. side of the cb trunk. I am not sure of the construction of this boat, i.e. what is under the outer ACP skin. I was reading in the documents in the download library about fixing cracks with Devcon Plastic Weld. The six holes the screws go in in the transom are relatively intact, but aren't tight enough to hold the plate on. How do I re-do the holes and is that layer of caulk still stuck to the transom where the plate was, 3M 5200?
