So, I bought a M22 this year. It started life on the salt, but has been freshwater sailed for a long time. I will only be freshwater trailer sailing with the boat in the water a couple days at a time max.
The rudder has several things I want to address. Whatever it was painted with last has degraded and now anytime it touches anything it leaves nasty stain. There are the usual nicks and dings. And it is not watertight so when you pull it out, it leaks for a while.
I have done fiberglass repair, but never any gelcoat. I was planning on cleaning it, fiberglass it fair, and then probably paint it with oil based enamel.
I live in Montana away from marine suppliers and since it will be freshwater trailered I wasn't worrying about using bottom paint.
I have seen some threads where folks leave a hole in the rudder so that it will fill with water and not have to fight as much to keep it in the down position.
I would like anyones advice on my painting plan and the issue of whether to put a drain hole in it.
