Adapt, improvise, overcome.
Mar 30, 2013
700
Local club races yesterday, great day for racing on our lake, winds running 12-14kts and unusually constant for us. We were doing pretty well all things considered. We just made the turn were making the run for the line at the end of the first race when I leaned a little too hard on my tiller when the boat heeled up and **CRACK**.
The tiller split about 1/3 of its length.
We crossed the line and cleared the course, dropped the jib and went into damage control mode
Wire ties and para-cord saved the day.
I'm going to try to repair this one but I think I'll be shopping for a new stick,
Jul 6, 2013
223
Catalina 30TR, Atomic 4 2480 Milwaukee
Local club races yesterday, great day for racing on our lake, winds running 12-14kts and unusually constant for us. We were doing pretty well all things considered. We just made the turn were making the run for the line at the end of the first race when I leaned a little too hard on my tiller when the boat heeled up and **CRACK**. The tiller split about 1/3 of its length. http://s23.photobucket.com/user/FLHRI-OK/media/tiller split-1847.jpg.html We crossed the line and cleared the course, dropped the jib and went into damage control mode Wire ties and para-cord saved the day. http://s23.photobucket.com/user/FLHRI-OK/media/tiller patch-1845.jpg.html I'm going to try to repair this one but I think I'll be shopping for a new stick,
Very ingenious.
I repaired a tiller by squeezing some Gorilla glue in the split, and clamping together with a couple of SS thru-bolts. It will never crack in that area again.
Gunni
Mar 16, 2010
5,937
Adapt, Improvise, Overcome - indeed! Para-cord is an essential repair item. You can always mix up a pot of epoxy and paint it on! Well done sailor!
Mar 30, 2013
700
Very ingenious.
I spread the crack, drug some sandpaper through it and filled it with Gorilla Glue then clamped it together in 6 places. When it cures I'll through bolt it top to bottom with a couple of SS bolts. It won't come apart again there anyway.
And some of my fellow sailors at the lake have given me a hard time about all the wire ties and para-cord I have on my boat. :)
pateco
Aug 12, 2014
2,207
Always keep a fresh bag of CT-15B UV Rated Cable ties, and a spool of Para-cord onboard with the Duct Tape. There is a bag of ties in the tool kit in each of my cars as well.
Nov 8, 2010
11,386
By design, para-cord is very elastic; it's designed to stretch and absorb shock of the canopy opening. Not a great choice on a sailboat where in 95% of the potential use-cases, less stretch is best. A much better utility line is a 20 or so feet of thin dyneema. Almost zero stretch, and a few loops of it will lift the boat. Just learn good knots for it.
In my pockets at all times, my sailing knife with fid, a roll of e-tape, and a length of dyneema. I can fix and jury-rig almost anything with that kit.
Apr 25, 2008
35
Macgregor 25 Cabrillo Marina (San Pedro)Ca
Very ingenious.
I concur, added the SS bolts to my new tiller, the perfect fit.
Sep 20, 2013
12
Islander 37 Seabrook, TX
No, for this application stretch is good. When the cord is wrapped around the tiller and pulled tight on each turn it stretches a lot. With any small change the load changes due to the low spring rate of the cord, but is still tight - just a little bit less tight. When a low stretch cord is used and is stretched to the same tightness, the same small change will cause the load decrease much more. What you want to avoid is cord that relaxes with time under load.
Aug 24, 2014
7
MacGreggor 25 Portland Yacht Club
Glue it, drill it, and insert a recessed blind nut in the bottom, then use a hex head recessed bolt from top down. don't use phillips or blade screws, they will strip. THe bolt is recessed smooth/flush across the surface and the nut is the same on the bottom. Looks like new :D
Nov 8, 2010
11,386
Interesting thought process, but I'm not sure I agree! ;^)
If the goal is to hold the broken tiller together as tight as possible, I can't see why you would use a line that is going to stretch? Even if you pull it tight, it's still going to stretch more when the load comes on. You can't pretension it enough. Line stretches linearly to its breaking point.
I can see cases where if the goal was to be tight and there was going to be little or no additional load on the part that a line that you could pretension by stretching some would be an advantage. To me that's not the case here.
But at the end of the day, there is probably no right or wrong answer; only thing that is important is the resourcefulness to fix the problem enough to get you home!
Aug 3, 2012
2,542
The thing that struck me is we tiller-steer sailors don't often have emergency tillers! I am converting my 272 to wheel steer for next season, and I will keep my tiller and rudder head for emergencies, but I never had a backup for my tiller! I suppose I could drill and bolt a paddle to the stub pretty quickly!
Thanks,
Andrew
May 13, 2013
7
Kells 23 In my driveway
The thing that struck me is we tiller-steer sailors don't often have emergency tillers! I am converting my 272 to wheel steer for next season, and I will keep my tiller and rudder head for emergencies, but I never had a backup for my tiller! I suppose I could drill and bolt a paddle to the stub pretty quickly! Thanks, Andrew
Andrew,
I'm curious here as a newbie, and my apologies if I'm hijacking he thread here: why would you convert from tiller to wheel on a 27? What are the benefits?
Thanks,
Sean
Aug 3, 2012
2,542
Andrew, I'm curious here as a newbie, and my apologies if I'm hijacking he thread here: why would you convert from tiller to wheel on a 27? What are the benefits? Thanks, Sean
For me, they are the removal of a swinging tiller in the cockpit, the removal of the tiller clutch lines, the opportunity to work on my boat :), making the boat easier for my wife to handle, and a place to add some accessories and a cockpit table.
I lucked out by finding a new, in-box, RLA steering system with pedestal and wheel for the 272 for a fraction of today's prices. I have spoken to several slip-mates who have them, and they like them very much, so I bought it.
My wife will steer a little bit, but she gets overwhelmed by the tiller. I know I should get her to sail our Catalina 14.2, so she really learns to sail, but she is getting better every season, and seasons here are short, and the water is cold. The tiller seems to be a hurdle for her. Traveler, mainsheet, genoa sheets, halyards, lazy jacks, topping lift... dock lines, boat hook... She has them all in her pocket. I bought her a little Wahoo 16 powerboat this season, and she loves it, so she is coming a long way from never having been on a boat before she met me 10 years ago! She rocks that Wahoo, towing me on a wakeboard!
Tillers are generally more responsive, but I look forward to experiencing a wheel. I just couldn't see putting a wheel on my C22! I wanted a wheel when we moved up, but this 272 was a great buy, so I bought it. Not settling by any means. The tiller is great, but I want to try the wheel.
If anyone else chimes in, maybe the moderator will move this to a new thread.
Thanks,
Andrew
Sep 20, 2014
1,330
Rob Legg RL24 Chain O'Lakes
Gorilla glue it is not bad, however it is not remotely close to the performance of Titebond when gluing wood. If you had the normal drying type, you could have squirted it in the space, clamped it together hard, and ten seconds later it would be stronger than the wood its self, assuming the wood split, and the old glue did not prevent the Titebond from squeezing into the wood. Once you clamp Titebond, you are done. It will never come apart, ever.
Knowing it split with only a small amount of stress, I think I would be inclined to split it the rest of the way. That way you can really sand the old clue out. Getting the new glue to work requires the new glue to be pressure squeezed into the wood pores. If it is good and clean, I would see no need to replace it. That also assumes the wood is not rotted where the bolt holes go through.
As far a clamping, if you need to clamp to a small curved surface, we use packaging wrap. Several wraps of cellophane packaging wrap will pull it tight and as long as it is not too wide, will conform to any shape you need and provides continuous clamping force over the whole curve.
3rd generation woodworker.
BTW: I prefer a tiller, as it is easier to see/feel weather helm. I think it is also easier to tell what you are doing when docking, particularly when backing up.
Likes: 1 person
JamesG161
Feb 14, 2014
8,020
Hunter 430 Waveland, MS
I build curved staircase and rails and laminated beams as part of my work too.
Right on target Daveinet:dance:
The key is enough time after bonding with, bunches of clamps, to cure. Clean the excess glue off after the clamp squeeze.
Jim...
capta
Jun 4, 2009
5,072
I've used hose clamps several times for this sort of repair. If it's too large for one clamp, you can put as many together as necessary to do the job. Add a bit of Weldwood (spar making glue) and in a few days you have a permanent fix.
Aug 27, 2015
58
Cal 2-46 Whitianga. New Zealand
You can see that the mechanics of the tiller design at the stock puts strain at the bolts. Also for the laminate to split like that indicates the glue used is inferior. A typical 2 pot resin glue would not do this, more likely damage the wood than just release.
Couple of suggestions.
1/- carry the split the whole length. Grind both surfaces back to raw wood. Mix up some 2 pot resin and glue poser. Cover both surfaces. Clamp well th entire length so the glue oozes out.
2/- improve the mechanical disadvantage by making two stainless steel checks to attach from the three stock bolts plus a further bolt through the tiller. This will spread the load and make much stronger.
Pete
Gunni
Mar 16, 2010
5,937
I don't think Titebond glue is rated for marine use. I know they have some new formulations but epoxy would be the choice for a tiller handle that gets constant exposure, and provides critical function. Even resourcinol would be preferred, but the bond is less elastic than the better epoxies.
