Bondo repair under the water line
Sep 9, 2015
28
Catalina 22 Tyler, Tx
I have a Catalina 22 I bought that was in a slip for at least 4 years. I trailered it and found some blisters. I also found a small hole in the hull that was not blistered but did leak "caramel candy". Yes, a stream of sticky brown ooze ran down the hull of my boat about 1 foot starboard of the keel. This solution smelled of butterscotch. When I started to grind it down, I found a grey substance - automotive bondo with no gelcoat over it, just paint. Chisiled out the bondo and found a 2 1/2 x 3 inch area that was roughly ground out with a dremel. forget the 1:12 fairing grind, it was almost straight up into the hull about 1/4 inch. After taking out most of the grey bondo, I found that water or some liquid was leaking out through the edges of the grind into the bondo that was left, turning that bondo brown and tacky and smelling like butterscotch. What can I do? couldn't post a picture.
May 19, 2014
77
Catalina 22 wing Westbrook CT
Post this in the Catalina 22 section. No one looks here. I think you have water soaked wood under the FG somewhere and that's where the ooze is coming from . Generally a deck problem.
Sep 9, 2015
28
thanks, will do
Nov 24, 2014
196
Catalina 310 Staten Island
Using bondo below the water line is like standing in front of a Sherman tank with only a police issue bullet proof vest
