I have a Beneteau 311, Footloose, and I have been working on getting better tacking angles when going to windward. I measured the jib sheeting angle last night and it works out to almost 15 degrees. For a cruiser that aspires to good performance I would have expected something like 7-10 degrees. The angle I'm referring to is how far out to the side the jib lead is from the centerline of the boat. See for example this article and the second diagram: http://www.sailmagazine.com/racing/regattas/headsail-sheeting/
I have two questions:
1. Do you agree that this sheeting angle seems high?
2. Would using an inhauler (Barber hauler) help me to get a little better angle? The track is about as inboard as it can be without being mounted on the cabin. Or would using an inhauler just make me pinch too much and slow down?
The Neil Pryde tuning guide for the OEM sails suggests that the sheet should be pulled in until the leach is no more than 1/4 of the way in from the outside end of the spreader (1/4 of the length of the spreader). This amount of tightening adds a few more degrees of lead angle.
Thanks in advance for your thoughts.
