the carling switches are good, first class switches but the carling technologies company has extremely poor customer service and the switches are not easy to come by.
you can contact them and let them know what you need, but their follow up is non-existant... even when you do the call back and try to get the info you originally contacted them for. their email correspondence is also slow and it seems as if the person on the other end is a beginner in the business....
you need to find an independent electronics store and order thru them, as they know where to source the switches that cannot be found on the internet.
so many internet outlets advertise the part numbers as "in stock", but they cannot actually get them from carling any better than we can....
the prices can vary a LOT from one place to another and unless you only need 1 or 2 pieces, they will almost always need to be ordered.
I am in need of some of their mid sized, lighted, amber rocker switches and cannot get them for any less than $22 per each, plus shipping.... so I am still using the red ones in place of where the amber ones should be.
I have found them sometimes as low as $5 which is more reasonable, but they are usually out of stock on the ones I need, when i need them.
this has been my experiance with the model of carling products that I usually have to deal with, in my boat and in my equipment repair business, and i dont expect it to get any better with them.
its unfortunate that I dont know of a better, more dependable switch manufacture for these switches.
as for a simple conventional style toggle switch, I have a vendor I purchase from that supplies me with mil spec sealed waterproof switches that are extremely well built and dependable for years of use. these can be obtained in any configuration one could ever have a use for, but the panel on my boat has rocker switches, not toggles, so im still stuck with trying to get the carling rockers....
if you find a good dependable and affordable outlet that can actually supply us, please let me know...
the rockers I need are,
carling switchs
Amber rocker= LRA511-CA-B/012V
Green rocker= LRA511-CG-B/012V
red rocker= LRA511-CR-B/012V
