Engine Flush
Oct 29, 2005
2,366
I came across the STP Engine Flush and was wondering if this would positively impact my 13yr old 1400hrs 2GM20F Yanmar.
Any suggestions/thoughts from fellow sailors?
Jan 4, 2006
7,438
Depends .....................
........................ on what the old antifreeze looks like coming out.
I change mine every two years to keep up the corrosion inhibitors. And I say every two years because I'm too lazy to drain the domestic hot water heat exchanger and related hoses. The old stuff coming out is as clear as the new stuff going in so I've never considered an engine flush. I use distilled water in the 50/50 so there's no concern about scaling.
If the old coolant is full of corrosion products, an engine flush may be in order. However, the more important issue would be to determine the cause of the corrosion correct it.
Oct 29, 2005
2,366
This engine flush is for crankcase not cooling system.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
why not just put a pint of Marvel Mystery Oil in the crank case and run it for a while and then change to no oil.....not sure you need to do anything at all unless it has been neglected over time ...like to long between changes and filters ......they don't get much dust in them being on the water and if it has been using the proper recommended oil all this time there should be virtually no paraffin buildup ...have you had the oil analyzed
Oct 29, 2005
2,366
Have not had oil analyse. Dont think theres such service here and if there is, its gonna cost a bomb.
Will check out MM Oil.
Nov 6, 2014
122
Yankee Yankee Seahorse 24 Beaver Lake
Unless the engine has been running for long periods of time below the recommended operating temperature, you probably do not need engine flush treatment. I have seen this when people remove a stuck thermostat and forget to install a new one.
Running an engine in cold weather without the proper thermostat installed can cause sludge buildup. A milky white buildup will accumulate in the engine if the engine cannot get up to the recommended operating temperature.
There is a video on Youtube that shows how to use the STP engine flush. If you decide to use it, follow the directions to the letter.
Changing the oil and oil filter on a regular schedule provides adequate crankcase cleaning as long as the engine is operated at the manufacturer's recommended engine temperature.
Johnb
Hunter 37-cutter Richmond CA
If it ain't broke don't fix it
If you can't fix it don't break it.
For an experiment, the next time your hands are oily/grimy try using a little engine oil (maybe Shell Rotella T) as though it were soap - rub it in. You will be amazed a how it dissolves the grime. It still needs to be removed with soap but this demonstrates (at least to me) how well the detergent works. I would not bother with anything beyond maybe lowering the interval between oil and filter changes, or what I did when I first bought my boat, a double oil change. (I also did a double coolant change)
I figure oil additives are like vitamins, the biggest benefit is to those who sell them to you.
By the way, when Woodster referred to changing to no oil I wonder if he was making a sarcastic reference to the advertising video that purported to show that after a certain oil had been used the engine could run with no oil.
Oct 29, 2005
2,366
I've seen the video on the car that uses no oil after coating internally with teflon like product. Amazing.
Too risky to use on a boat.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
That was supposed to read new oil. These I phones are great at times but some times they will put words in your mouth. Lol the part about the iPhone wast sarcastic part lol
Oct 29, 2005
2,366
I've found a lab able to do the oil condition test. Wrote to them. Btw could anyone advise estimate cost of this oil analyse in State? Price here is usually same in US but in SGD instead.
Thanks.
Jan 26, 2008
50
Hunter 31- Deale
Just change filter & oil (quality diesel oil) every 50 hours or once a season. Run the engine at the proper speed/rpm; don't idle or run at low rpm for extended periods of time. With a warmed up engine run at high or wide open throttle for 2 minutes each time out. I do it on the return.
Jul 1, 2014
256
Hunter 34 Seattle
Thanks.
I had an oil analysis of both the engine and transmission as part of a mechanical survey when I bought my boat last year. Seems like the add for the analysis was about $50 per test.
There are places online that will send you a kit to return with your oil sample. But you might be able to find a service locally, it is a service routinely used by businesses that run lots of diesel (and gas) equipment to monitor wear and know when service is needed rather than waiting for it to break down unexpectedly.
Jan 30, 2012
1,150
Ken
Try Blackstone
www.blackstone-labs.com/free-test-kits.php. They send you the sampling kit for free - the analysis is $25 US.
For what it is worth - I avoid all 'crankcase flushing' products because flushing achieves no benefit in addition to periodic 100 hr. oil changes.
Charles
Johnb
Seems like it does:D
Aug 16, 2006
281
Ericson 32 Oregon coast
In a word, they're gimmicks.
Modern oils have additive packages that are nothing short of incredible. Included are detergents, friction proofing and corrosion inhibitors. Actually, introducing another additive can reduce the qualities of that package. The sage advice of old that is even more important today is to "CHANGE YOUR OIL REGULARLY". Nowadays engines tend to outlast the cars that they are in, largely due to the improvement of motor oil. It's a tedious and not so glamorous thing to change your oil but that is the key to engine longevity. It's amazing to me the extent that most people will go to in an effort to avoid that chore. Be sure also to use diesel rated crankcase oil in diesel engines and use the recommended viscosity.
