Problem solved, just bust out your Visa card!!
http://www.catalinadirect.com/index.cfm/product/730_373/hatch-trapezoidal-bomar.cfm
I like that hatch too. It is the reason I wanted a "new design" hull or better. Today we went down to the coast and measured for the new main sail. While there we thoroughly scrubbed and bleached the interior, cleaned the fresh water jug and tested sink pump and repaired the mushroom caps on the forward hatch.Welcome bushav !
Nice looking boat. She doesn't appear to need much work at all.
Good move on the sail. IMO it makes a lot more sense to simply replace it, when they get that bad.
I must say I'm a bit envious of the forward hatch. My "new design" has the fiberglass one with the goofy tiny deadlight.![]()
I checked out the manufacturer he used in Columbus, GA. They gave me the second best quote. We have a magic tilt dealer close by who quoted $2650. I think I like the magic tilt design better. For sure I want bunks instead of pads.Yup, Gene did have a new trailer built but he has swing keel. Another member, W4swk had a trailer built for a Wing keel. details on both are in this thread;
http://forums.catalina.sailboatowners.com/showthread.php?p=1212211&highlight=C22
Have you guys found a soured for replacement trash cans that fit the galley hole?
Lane
The running rigging is shot! Ropes old and mildewed. I want to fancy them up with the colored ropes in the spring. I think one of you guys posted the list of required ropes somewhere. I'll have to find it. Is there a guide for standard color usage on the ropes?
I have the four prong plug. I think one post is larger than the others but strangely is not the ground.
Lane
Further to what Luke has said...I have the four prong plug. I think one post is larger than the others but strangely is not the ground.
Lane
Lane
Try change the file extension to .txt then attach it.... it would be helpful is someone could tell me how to insert a spreadsheet as an attachment on a post so we could all save ourselves a bunch of PM's and emails!
Trash can was/is "Rubbermaid #2845 wastebasket, 14 1/4" x 8 1/4" x 15"Have you guys found a soured for replacement trash cans that fit the galley hole?
Lane
