Fischer Panda Not Starting??
Aug 12, 2013
7
Hunter 33.6 Sandy Island, SC
I am having problems with my Fischer Panda 4200 Compact Series not starting...i have replaced battery and have significant amount of Fuel in Tank...Sounds as if she's not firing, only have 30 hours on the unit...Any ideas of what might be going on to get her going would be greatly appreciated...
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
info
More info would help
What happen to start it not starting anything changed,is it turning over
good and is it getting proper fuel if turning over well.
I have same FP and have had miner things happen and took care of it,it has 2 relays one for starting and one for fuel pump and cooling.Check oil and any red lights when starting but if turning over OK than maybe not getting fuel so have some one push start button and try open fuel line see if getting fuel first.
Nick
Aug 12, 2013
7
More info would help What happen to start it not starting anything changed,is it turning over good and is it getting proper fuel if turning over well. I have same FP and have had miner things happen and took care of it,it has 2 relays one for starting and one for fuel pump and cooling.Check oil and any red lights when starting but if turning over OK than maybe not getting fuel so have some one push start button and try open fuel line see if getting fuel first. Nick
Thanks Nick
Hum, where do I begin...First I will start with I was at Dock on Shorepower and my breaker flipped so upon investigation my Shorepower/Generator switch burnt up, had a technician come out and replace switch...This is my first time trying to start the generator since the new switch was installed, it turns over several times and fires maybe once or twice....But will not start, I didn't know if it might be a fuse or something minor that I could do myself rather than calling another technician... Any helps greatly appreciated!
Dec 19, 2006
5,836
check
See if getting fuel and trace fuel line back to electric fuel pump and see if pumping fuel,disconnect hose on fuel pump and turn over and check for fuel pumping.
If pumping fuel OK than 2 relays I replaced once each one and if not pumping than maybe relay is bad,left side relay is for starting and right side for fuel pump.
Maybe when burned up switch some thing else got damaged.
Got relay at auto store and on line
Nick
Dec 19, 2006
5,836
electric fuel pump
I don't know if you have a manual but go on internet you will find a complete
manual for your 4200 FP and it will help understand how some things work.
The 4200 uses a external fuel pump and mine has a fuel filter also and I am not
a expert but was lucky never had any real problems and by trial and error and hard to find some one work on mine.
One thing I had to do was replace one of of the 2 relays and now keep a spare and did need to replace the starter due to my fault,FP in Florida did help me figure out what my problem was and they have been very helpful and so far my 4200
runs great.
Nick
