Empty Holdibg Tanks on Beneteau 473
rbelau
Jun 29, 2014
7
Beneteau 47 Stonington, CT
We are planning an offshore trip. It it possible to empty our (waste) holding tanks overboard (once sufficiently offshore)? Under the sink in the heads, There are valves with settings for holding tank or overboard. But that seems to apply to the handling of new waste being created, I.e. Where does a new flush of the toilet go. Is there a way to pump out what's already in the holding tank overboard too? It seems to me when I move the valve to open the overboard path, I'm closing the holding tank path, so I'm not sure how anything can get out of the tank.
7,569
Alden 50 Sarasota, Florida
Do you have a macerator?
If not, it the elevation of the tank such hat you can gravity discharge?
Jul 19, 2015
154
Beneteau 343 BVI
If it is like mine the valve is either open or closed. All the waste still runs through the holding tank.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
The best thing you can do is study the installation of a marine head in the west advisory and look at all the possible ways to do that then you will have mental picture of what to look for on your boat This stuff gets to be like an Easter egg hunt at times. It boils down to good visual detective work at times
Dec 2, 1997
8,993
- - LIttle Rock
Yes, but unless it's already installed, you'd need a y-valve in the TANK pumpout line, with hose coming off one side of that y-valve going to the deck pumpout fitting, hose coming off the other side of it going to an overboard discharge pump (electric macerator pump or manual diaphragm pump)...from the pump up and over a vented loop to a below waterline thru-hull.
IF the plumbing is installed, that setup gives you a choice of flushing the toilet directly overboard or into the tank.
Yep...what I described above. I suggest you get some knowlegable "eyes on" help in determining what plumbing is already installed and what needs to be installed to do what you want.
That setup only lets you flush directly overboard, you'll need the plumbing I described above to dump the tank.
However, If the plumbing isn't already install to let you flush the toilet directly overboard--and I'd bet real money that it isn't--I'd have it installed so that you don't have to mess with dumping the tank while in open sea outside the "3 mile limit." It's not hard to install (you will need to include a vented loop in the line between the valve and the thru-hull), and will make your life much simpler. Use the tank only when you have to.
Catalina 320 Dana Point
Most of the newer French boats I've been on use a small green 6 gal. (?) tank which is located behind the panel in back of the toilet. The tank is above the toilet and dumps by gravity, tank is connected by hose straight down to thru hull. Open valve, tank dumps, no pumps involved. Usually the intake valve is located beneath the sink.
8,993
- - LIttle Rock
There are 4 hoses connected to that tank...The one coming out of the bottom is obviously the one that goes to the thru-hull (which had better be below waterline!)...one of hoses on the top has to be the inlet from the toilet, and smaller diameter hose has to be the tank vent...but what's the 3rd one do?
Btw....a Jabsco toilet can move bowl contents up to 4 vertical feet, but the inlet on the tank looks a good bit higher than that...which I suspect presents interesting challenges for owners who have to use the tank.
Jun 6, 2012
30
Beneteau 473 CT
Our 2007 B473 has a macerator pump at each head to empty the tank while offshore. This is a separate valve than direct overboard flushing of the toilet. But it's fairly well marked from the factory. OP: Do your hoses and valves have labelled tags from the factory?
rbelau
Jun 29, 2014
7
There is a Mascerator switch on the electrical panel. And in the head,there's a button that activates what sounds like a pump. I'm unclear though whether I have to move the valve to the overboard setting, or if that valve only applies to the destination of newly flushed waste. Does this Mascerator do it all without having to open a separate valve?
Dec 2, 1997
8,993
- - LIttle Rock
It may be labeled "macerator," but it could just as easily be a sump pump that a PO installed to use that circuit, but didn't bother to re-label. So you need to find it--and every other component in your sanitation system too. Trace the plumbing from the toilet TO the tank...and from the tank discharge fitting to the thru-hull. If you don't find it, check your shower sump.
One more time: If the valve is in the plumbing between the toilet and the tank, it provides the choice of flushing into the tank or flushing directly overboard. It has nothing to do with dumping the tank. It ONLY applies to the destination of new flushes from the toilet.
That depends on how the system is plumbed. If there's only a tee or wye in the tank discharge line, there's no valve to open. But if there's a y-valve in that line, it has to be turned to direct the tank contents to the macerator pump--which is JUST a pump with what amounts to a blender blade in it. It has no ability to open and close valves for you.
Again one more time: Get some local "eyes on/hands on" help from someone who's knowledgable enough to help you find all the components in your system and explain how they work!
