And in NH
May 4, 2005
4,062
end of link:
The vessel was taking on water through the shaft," said Petty Officer 2nd Class Craig Bren, a crew member from Station Merrimack River. "The crew stopped the leak, dewatered the vessel, and towed them back to port."
Jan 4, 2006
7,641
If it was the packing gland, I wonder what kind.
All U Get
I suspect there is only one type of seal that could leak that much water without a very slow slow and previous warning :eek:.
If it was that type of seal (which shall remain nameless), I wonder how the Coast Guard 'stopped the leak".
Nov 6, 2006
10,212
Sounds kinda like they failed the flex hose between the log and packing box.. A "twist off" kind of failure there would let in a lot of water and when the CG packed the log with something, they'd not be able to run the boat. One possible scenario..
Feb 3, 2009
58
Camper Nicholson 39 CC Rockland, Maine
I bought a boat that had a drip-less gland and the vessel had not been moved for a couple of years. When we started her up to move to a yard to be hauled for the survey the gland ripped. The two plates had fused together and when the shaft turned the bellows ripped apart. A whole lot of water started pouring in. We broke the plates apart and wrapped rags, line and tape around the bellows to slow the leak to a manageable amount and continue.
The drip-less packing glands need attention. They are not leave and forget equipment.
