83 hunter19
MPS
Mar 24, 2015
2
Hunter 19 Spruce Run
I bought a 1983 Hunter 19 this winter and its my first boat. It came from ebay so as-is. It looks complete but cabin, cockpit and bilge were very full of ice. I'm only now getting it drained. The wood panels in the cabin that give access to the keel pin holder were rotted, but maybe the hardware is okay. I plan to float it above the trailer and look down through this panel into the bilge to see if water comes in. Is this a good plan?
Also I keep reading about a water ballast for the hunter19, but maybe that's for the later models? I don't think this 1983 hunter 19 has a water ballast. If it does then I have no idea how it works. I saw a plug low on the transom, but I think that's just tilt the trailer and drain the bilge. I'm pretty sure that if I opened that plug the cabin would flood.
Thanks for any help. Matt
-na -NA Anywhere USA
two different boats and the earlier version I do not know the bilge or centerboard attachment...
take a photo of the bilge and check first in the water. Take a flashlight with you.
MPS
Mar 24, 2015
2
Thanks Crazy Dave. photos uploaded.
After crawling around, this centerboard mechanism looks like a concern. The caulk is falling out around the metal and there are hairline cracks in the fiberglass. I can't see any cracks from the inside, but it strikes me as a weak point. When the board swings down maybe it fits snug in its well, otherwise one good whack and there might be problems.
Told the owner to recaulk the centerboard hangers and the gudgeons for the rudder and then check for water penetration. Then go from there. Also advised on new tires if there is any dry rot and so forth,
Mar 20, 2004
1,749
Dave, I can't help with this one either - I had the water ballast model.
Chuck
Tom;
You will have to learn to navigate thru this site. Use the forum site and also the Owner resources for boat information and look up your model to include the downloads which has an owner manual.
Sep 10, 2012
24
ODay Javelin rangeley, ME
Sails
I have a like new jib for it. see my ad in classifeds
hope I'm doing this correctly
have a Hunter 19 1993- can anybody give me the demensions of the main and jib- have some sails but am not sure if they are the correct ones for the boat
tks
tom
p.s am still learning my nway around the website Dave C has been helpful
Feb 7, 2013
4
hunter 19 Eden isles
stock sail will have h 19 on it.
working jib
I or leech 16ft 11.5 inches
j or foot 7ft 6.5 inches
forestay/luff 18ft 8inches
Sep 10, 2012
24
Chuckkir98f
tks but I have a few questions that will disclose my ignorance
what kind of sails are available on the 19 - I know there is a main and a spinnanaker
Now I see there is a "working Jib" are there other kinds of jibs? is there a genoa?
Does I stand for leech?
Does J stand for foot?
Is there a letter that stands for luff?
Tom
Feb 7, 2013
4
Chuckkir98f
Tom
do a quick search on how to measure a jib. Sloops can use 4 sails. Main, jib, Genoa, spinnerker
Over the years, the size of sails or dimensions have been cataloged which the sail lofts can research or look up. However, for this boat, go to the owner resources, pull up the model and pull up specs as you will need the I,P,J & E measurements for the sail loft in the event they do not have any. If it is an old sail, good always to send it to the sail loft if replacing it.
