This fall I'll replace all the sanitation hoses on our boat. It is a 2003 so due I assume.
I'll add a holding tank clean out port at this time, easier to install a larger vent hose with access to the inside of the tank. I'll use the Trident 101 hoses as suggested by Peggy.
The Hunter PDF for the factory install of the head specifies 16 ft of 1.5" hose (seems like a lot ?).
Has anyone else done this job ? I want to make sure I order enough.
My plan is to use the old hose to pull the new one in. I'm not sure what route the hose takes and how much access I will have.
Thanks, Bob
Thanks, Bob
