On my 1985 30', my main sheet run from the boom blocks to the mast through a block down to a block at the mast base and then through a deck organizer and then through a jam cleat on the starboard side of the cabin deck. I think it is the original setup but it seems more complicated than it needs to be.
The main sheet has to go through a lot of different things each contributing some amount of friction.
Do most people use this system or have you found a better way to do this?
I almost think a fiddler block with a jam cleat at the traveler would work or would that be too hard to control? Just wondering.....
