SeaTalk connecting C80 & new ev100 autopilot
Jun 23, 2015
117
Hunter H34 Deltaville
Hi everyone, very new owner of a H34 hull #68 learning a lot. The boat came with a Raymarine C80 chart plotter I am installing an EV-100 autopilot that has the new SeaTalk -ng connections.
If I understand everything I read online the two different systems can operate together by splicing the lines. Before I fry anything by connecting the them together I thought I'd ask here.
Thanks
Dennis
11,711
Thanks
Dennis
You'll need the Raymarine SeaTalk to SeaTalkng converter kit # E22158..
Jun 23, 2015
117
Thanks Maine Sail, I've seen that before and it looks like it just has the different connectors on the same cable. As all the cables have already been spliced to get them up to the NavPods on the helm I was planing to forgo the kit.
By the way I just saved your article on battery bank vs. banks.
Bob S
Sep 27, 2007
1,805
Beneteau 393 New Bedford, MA
Try visiting the Raymarine Tech Forum.
http://raymarine.ning.com/
There is a lot of info there when it comes to installs and issues. I used the converter kit Maine Sail recommended.
11,711
You still need the converter to get SeaTalk 1 to talk to (convert the language/data) Seatalk ng . There is a chip/processor in the converter box and no way to physically "splice" Seatalk 1 to Seatalk ng because they are talking entirely different languages. Think of a Seatalk 1 to Seatalk ng converter as an interpreter for when you speak to a person speaking Chinese when you don't understand Chinese. No translator (converter bus), no comprende...
Jun 23, 2015
117
Thanks for the link Bob, didn't even think to check there.
MS, that was one of my concerns with connecting the different systems. I didn't know about the chip. Glad you knew about it. Just looked at the picture again and noticed the one yellow connection on the converter and it's matching plug. Much obliged.
Jun 6, 2006
6,990
Pretty sure that ng and ST1 are the same language but they don't operate on the same physical protocol (0-12 volts vs 0-5 volts)
Soooo
yes you can splice them if you understand how to use a resistor to drop the voltage.......need to know the amps.....and no warranty.....
The Ray cable is all you need as they know the resistor size and just install it in the cable. You can confirm by looking at the manuals on seatalk. the pictures clearly show ST1 cabling into a STng with no extra boxes.
Jun 23, 2015
117
That was my first impression when I saw the picture of the kit, $100+ is a bit much for what's in the kit. I will do some more checking. Last resistor I got of Ebay had to buy 100 for the one I needed, less than $2, anyone need a 330 chip resistor?
As of last count there are 4 crimp splices in the C80 lines due to the connectors not fitting- as per installation. I plan on soldering the connections and removing the extra 12' of coiled up line under the helm.
11,711
Soooo
The E22158 is actually a rather sophisticated piece of gear not just a splice with a resistor. It runs software and has had at least 5 or 6 software updates that I am aware of. It converts Seatalk 1 to Seatalk ng which is really NMEA 2K. For that conversion, ng to N2K, there is a simple cable but not for ST1 to STNG. There is a LOT that goes on in that little converter and no a cable with resistor won't work...
Apr 27, 2010
968
Beneteau 352 Hull #276 Ontario
Seatalk is ray's propriety version of nmea 0183 at a speed of 4.8kbaud.
Seatalk-ng is ray's propriety version of nmea 2000 at a speed up to 56kbaud. Also based on the CAN Buss. This was actually used by PLC based systems (DeviceNet) long before Ray used it as a protocol
The 2 can't be combined without the interface which matches up each of the protocols.
Aug 1, 2011
3,972
The words are different, the protocols are different, and the length of sentence is different. A whole bag full of resistors is $8.00 delivered from DigiKey, but not a single one of them will do the conversion.
The itc-5 also allows interfacing of older sensors, so there is some, although small, ancillary value in it.
You can (almost) directly plug in a CANbus device. That much is pretty cool.
Blitz
Jul 10, 2007
711
Seidelmann 34 Atlantic Highlands, NJ
Exactly, be sure to do the software updates or to this converter and all instruments on the Ray marine system before thinking it's not working. The ray marine technical forums are good if you get stuck along the way.
Jun 23, 2015
117
Wow, thanks everyone. Again looking at a picture of what's in the kit I didn't realize they built electronics into what looks like the terminal block that came with the EV-100. I'm defiantly going with the kit now.
May 10, 2008
392
Catalina 355 Boston
As Maine and others have noted, the converter is equipped with firmware and is required. A couple of things to add. Since you have an older CP, make sure the converter is equipped with the latest firmware update before installing. The newest CPs finally allow an upgrade via a download, but with older with older
Plotters you actually have to send the converter to Ray to do the upgrade. As an example of this, I upgraded a 3 year old Chartplotter this spring and my AP would not calibrate nor could I go to a WP or follow a route without upgrading the converter and the AP control head. Fortunately I could do the upgrade via micro SD cards.
In your case it will be much less painful to install a converter that is up to date....
Jun 23, 2015
117
Solstice, I had tried to update using compact flash card as per instructions but the website no longer supports the C80. How do you upgrade converter as the picture of the kit shows nothing that even looks like it has electronics.
11,711
If you don't have a newer plotter you ship it back to Raymarine in Nashua, NH... If you purchase it through a high volume dealer such as Defender the software should be pretty current. There was an update IIRC that dealt with the Raystar 125 GPS antenna which with an antique plotter like the C-80 you are likely using..
May 10, 2008
392
Catalina 355 Boston
As Mainesail says, you ship it to NH. There is a newer update for support of the newer APs. You can find the latest rev on the RM tech site and the box the converter comes in will have the rev version on it. You can ask whoever you buy it from to check the revision for you before they ship to save you a step...
11,711
Last update was V1.21 in March of 2013... Everything out there, theoretically, should be V1.21 and it will say it on the bag next to the bar code...
Jun 23, 2015
117
MainSail do you mean the AP has to go to RM or the C-80?
