We have a Hunter 356 and use shore power while at the dock. The 30 amp circuit breaker has worked great with no trips or surging for almost 1 year. The boat has an indicator for ground and galvanic isolator conditions and both have been in the green "Normal" range. If there were an issue, it would flash and beep "Fail" We also have an after market charger/inverter on board.
We have been told we need to replace the 30 Amp breaker with a GFCI. We located a GFCI breaker compatible with a "Homeline" breaker box. We found a Cutler-Hammer 30 Amp GFCI (with a 5mA interruption limit for tripping). When I installed the GFCI, the breaker immediately tripped when I plugged in the shore power cord. I tried to turn everything off (A/C main and D/C main) and it still tripped. I then switched off the main into the boat and it stayed on... Until I switched the main breaker to the boat back on. Then click...tripped again.
I think the 5mA might be too low of a cutoff and maybe a 10 or even 30mA cutoff might do the trick. My question is does anyone have any similar issues with GFCI supplying the dock plug tripping? I should also mention, there is another in our marina who put in the same GFCI and it works fine. His sailboat is much smaller and has fewer electronic systems.
