Keel on 30 O'Day
Feb 18, 2011
93
Catalina 42 42 Windsor
Is the iron keel in the 30 O'Day (early 80's models) encapsulated completely or are there bolts showing in the bilge?:confused:
Jun 11, 2004
1,926
Oday 31 Redondo Beach
On my 1985 O'Day 31 (which is really just an extension of the 30) there are keel bolts and nuts in the bilge. I would assume it is the same as the 30.
Our 85 ODay 28 was a lead keel, so possibly a different construction from the iron ones that I've heard they used in the earlier 80s.
So you have no bolts?
Sorry for being unclear. We had exposed bolts on our 85 with lead keel. I just meant that although mine and Richard's bolts are exposed, that might not match earlier models with iron keels.
May 6, 2010
472
1984 Oday 39 79 Milwaukee
Our 34 with iron keel has exposed bolts.
I am curious about something else - most if not all the larger O'day's I can recall seeing do not have the keel to stub joint faired, there is just an indentation where you can see the bedding compound. Curious why it is not faired, and if anyone has had success fairing it, or if it is just going to be prone to cracking?
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
The bedding compound should be flexible and it shouldn't "crack." If a bunch of fairing compound was slopped on and hardened, depending on what it is, it is probably brittle and that is what would crack if there is relative motion of the keel. I'd suggest just taking a scraper and scraping some of the old compound out of the joint then put a bead of 3M4000 or equivalent and fair that as best you can. The 3M compound should stay flexible and prevent leaks, Repeat every few years. I met a guy with a C&C years ago and that's what he did to his keel and it worked well.
