After installing the back winches on the 270, I find that the lines aft of the EZGlide cars touch on the stb side and rub on the port side. I made a couple of mounts for foot blocks, and while the port one through bolted nicely through the lazarette, The Stb one will not through bolt without the boltheads being in the aft berth.
Here's the question: If I grind away the gelcoat, would a nice coat of epoxy be sufficient to hold the base if the block was attached with screws that penetrated the core? The block isn't very large, about 2" wide and 3" long, and the sheet loads could be quite high given that we're talking close to a 90 degree bend.
Any input welcome. Glasswork is easy, calculating shear factors is way beyond me.
