I have read that the boom height pre 85 should be 3' 6" from mast step to top of boom does this sound right? mine is set way to low and I wanted to make it right. Thanx again as always Alan
Im not familiar with this concept as it relates to the boom and thinking about how it might work....Mine goes up and down according to wind conditions. The higher the wind, the lower the sail.
Center,Im not familiar with this concept as it relates to the boom and thinking about how it might work....
I can understand the sail is lower in higher winds if it is reefed, but do you also have a slider on the mast so that you can lower the boom on the mast and reef also?
l would think it would be best to have the boom lower on the mast in lighter winds as well so that you can maximize the sail area, with the exception that the luff of the sail is only so long and the head of the sail should be as high as possible in light air...(in heavy air you can reef the main) so unless you have an assortment of main sails with different lengths on the luff, it would cause one to think that the boom could remain stationary on the mast.
to the op, the head of the mainsail should go to the top of the mast, and the length of the luff will dictate where boom has to be attached to the mast.
it IS possible that someone has changed the main and moved the boom to fit the sail, as it does sound about a foot high to me, but then I dont know the sail plan for that boat....
Center,
Early Catalina's were often equipped with a sliding gooseneck. See image below. A line held the part in place and kept it from pulling up when the halyard was tightened. I'm never understood really why. Its not a great idea. It functioned poorly as a cunningham. Catalina now offers fixed goosenecks as retrofit parts.
