What is the best way to get the coax thru the cabin top?
I am using rg8x coax.
I need to go from mast base to inside cabin.
Should it be a PL-259 male connector on coax exiting from mast?
Connected to a Pl-258 (double female) that goes thru the cabin roof to be connected to another PL-259 on the inside going to the VHF?
Question what do I use to seal up the PL-258 going thru the deck?
I see a Blue Sea Systems Cable Cam on line that comes in three sizes.
Which is the correct size to cover the PL-258?
Or if I'm off base, what should I be using? I allready have the RG8X.
Thanks, James
Thanks, James
