While living on our boat last January we had quite a scare. Suddenly the cabin filled with smoke. We were in a slip on shore power. Sherry and the dog got on the dock right away, I pulled the shore power plug, turned batteries off. Then opened the hatches and ports. The smoke was coming from under the aft berth where our Seaward water heater was installed. Fortunately it is quite accessible, I had it out of the boat and onto the dock quite quickly. It was still smoking. The smoke quickly cleared in the cabin and fortunately did not leave any residual smell. We were lucky that we were on the boat when this occurred. We now only turn the hot water tank on now when it is needed, and never leave it on when we are not on the boat.
I opened the heater to investigate the problem and photographed what I found. It appears the black wire got red hot, melted all the insulation off of it and burned all the insulating paper. Had I not been on board to turn the power off I don't know how much further this may have progressed. The thermostat and high temp did not open because the water did not over heat and the heater did not exceed the breaker trip current. I think maybe the black wire was corroded and turned into a high resistance. The water heater was built in 2003. The tank was installed in a very dry location, showed no corrosion at all.
I contacted Seaward, reported the problem, sent them the photographs and the electrical components. They promised to submit the parts to a lab for analysis of the fault, and let me know the results. So far I've heard nothing more so I decided to post this as a warning to others about the possible danger of leaving the water heater on when no one is aboard.
Bob
Bob
