Has anyone had success using a depth transducer from an old Standard Horizon Depth Instrument with a Simrad Multifunction Display (MFD) ? I've got a new NSS8 mfd. Old Std Horizon DS-10 transducer. The transducer has only a two connector RCA plug ... wondering if I can use it with the Simrad.
Follow on question .... if that old transducer will not work ... does anyone know if a new Simrad transducer is the same diameter and fitting type as the old Std Horizon transducers? If I need a new transducer, it would be nice if I could use the same thru-hull without pulling the boat out of the water to install a new thru-hull.
Thanks!
Thanks!
