Any reason I can not run a line to both ends of the boom with a loop in the middle and attached the preventer to the loop?
Its not the same and it wont allow the full potential of the preventor... but it would still be better than attached to the vang bail.
Ive spent 20 minutes trying to figure out how to explain why, without a long and lengthy presentation, but
Basically the angles would be wrong and it could induce compressive stress in the boom, which could cause it to buckle much in the same way as the boom being forced out of column by the preventor being attached to the vang bail.
And using a sling on the boom to attach the preventor to only adds unnecessary complexity to an otherwise simple process.
When you change tacks, you.would have the move the sling aroung the vang to the other side of boom as well as moving the preventor line...
When a person rigs the preventor from the fore cleat, all that needs to be done to change tacks is unhook the preventor line from the boom, take it around the mast and reattach it to the boom on rhe other tack.
My boat is rigged with 2 preventor lines... one going to port around the mast and one going around to starboard.. both attached to the bail at the end of the boom
All the crew has to do is loosen one line from the fore cleat, let me tack around, and as soon as the jib clears the deck on the new tack, the other preventor line is then snubbed down.. this prevents the need for uncleating at the bow, then returning to unclip at the boom, taking the line around the mast and reclipping on the other side, then going forward again to cleat it down.. with two lines its fast and simple.
As ive said, the preventor lines are rigged with a deep clew hook that clips to a bail on the boom end, so to set it up and take it fown for stowage, its just a matter of slipping it on the bail and running the lines... or unclipping it and coiling the lines together..
