I am a newly registered SBO user but have followed the forum here for years. I’ve been having some lurking questions as to whether my current house bank is behaving as it should. I thought I would ask what others experience has been. I've read many posts by Maine Sail and have poured through the pbase site in addition to posts here.
Here are the details:
1998 Tartan 4100 - new to me in Spring 2014
Two 8D west marine gel batteries (rated at 225 AH ea. New in fall 2009) plus a class 31 starter battery (new in 2014) for backup.
Alternator is a Balmar 90 series 100 amp alternator.
Balmar external regulator MC-614.
Balmar SmartGuage for detecting SOC
My daily amp usage comes in around 105 amps.
Typical sailing is 3+ days out prior to dockside power
1-2 weekly trips before shore power is available
Here is what I experience. During bulk loading (house bank only) when my battery SOC is ~65-70% I can test the alternator output with a clamp on amp meter. The amp current is ~40 amps. I test this both at the alternator and the bank itself. They’re both the same. So I know I’m not getting much voltage drop from the alt to the house bank. This is lower than I would expect and I would have thought the bulk loading would be pushing way more current that 40 amps. When the regulator steps into acceptance, the amp current drops to ~15-20 amps. I realize that you’re only going to charge to approx. 80% and will get a significant diminishing return beyond that point. Typically, I will see bulk charge for about 30 minutes then go to acceptance. So I always feel as though I’m never able to push back into the batteries what’s being used.
When I return and plug into shore power I have a 100 amp Freedom 2000 inverter/charger. When that charger turns on, it’s only pushing ~40 amps while in bulk also. So the good news is that I see the same amp current while on shore power as I do from my alternator. The bad news is I still think it should be pushing in more amperage.
Do you monitor anything similar on your batteries and charge mgmt. system? What is your experience? I’m trying to understand whether I have an issue with my batteries just being old or whether what I’m experiencing is in line when batteries are at this SOC.
I would greatly appreciate any feedback or further questions.
SayWhen
SayWhen
