Cruising Florida: Offshore Sailing a Hunter 260
Jan 18, 2014
238
Hunter 260 Palm Coast, FL
Experiences Shared:
There were plenty of opportunities on my trip to have all sails out: down the Biscayne Bay to Key Largo, to Channel #5 (passing underneath the Key’s Overseas Hwy) to the Atlantic, all the way to Key West, and through the Florida Bay to Cape Sable, up the Gulf from Mexico to Marco Island, from South Naples to Fort Myers and finally, if you like, crossing the Lake Okeechobee.
Security Measure:
Used to protected water sailing security concerns come up when sailing or motoring the open.
Who wants imaging falling off and seeing the boat sailing or motoring away? It needs some security measure.
I used a ½” dock line, tide securely on pedestal and mast, hooked up a 6’ tether ribbon with quick release and attached it to an offshore automatic inflatable PDF with integrated harness.
Also I made sure when motoring that the emergency engine stop line was hooked up too.
The jack line became a good hold-on when going down in the cabin to pick something out of the fridge, etc., the tether followed.
It worked well out for me to have this security support especially by working on the main or when being on the anchor locker.
Sailing Experience:
It showed that my Hunter 260 needing constant rudder correction to maintain the course in about 10 knots of wind. Every wave or small change in wind intensity seemed to make the boat drifting off course. I reefed the main at about 10 knots of wind and it got a bit better; the boat speed was about 6 Miles/H.
There was no way to get relieve by use my wheel brake in the hope to let it go for a moment; it seemed the rudder might be too small for that boat in that circumstances. Thought it would be more relaxing when sailing in the open as experienced.
Well, there were some equipment I wished to have, like an autopilot and a windlass. But the H260 is not really designed as a cruising boat. I wished also a nice, separated berth, but the huge table with sit option for 10 people showed, that the designer had something else in mind.
11,386
Nice sail!!
Is that REALLY your boat's mainsheet was designed; with the sheet block floating in mid-air??? That must be a nightmare to use; in particular to release!!
Jan 24, 2009
451
1981 Cherubini Hunter 27 Shipwright Harbor Marina, MD
"Well, there were some equipment I wished to have, like an autopilot and a windlass. But the H260 is not really designed as a cruising boat. I wished also a nice, separated berth, but the huge table with sit option for 10 people showed, that the designer had something else in mind."
It's interesting how the market evolved, my 1981 H27 has doors between the head and the V-berth, but tons of teak inside. Yours is just the opposite.
Getting down the Potomac and sailing the Bay for week or so is on my list for the next year or so, I am definitely envious you were able to get out.
Dan
May 24, 2004
7,228
CC 30 South Florida
Nice sail!!
It was mainly designed for the tiller steered boats which comprise the great majority of the h260 models. Adding a steering wheel seems to have been a factory after thought. On the wheel equipped boats operating the sheet block is very inconvenient so many owners raise it by adding a line between the block and the "U" bolt. Have seen some as high as the binnacle.
Jan 18, 2014
238
Thanks Benny,
I was going to say that it was very uncomfortable to reach and adjust the mainsheet as low attached since behind the pedestal. The extension works very well on the H260 with steering wheel option.
Most of us learned that one of the better enhancements is an autopilot. It does two things: 1) relieves you of steering full time - better lookouts, can do other things while on the move; 2) teaches better sail trim (buy Don's book, it's great); if the ap is fighting the helm, then you have to LEARN BETTER SAIL TRIM to reduce the amount the ap is working.
Good luck, sounded like a fun trip.
Kivalo
Jun 5, 2011
116
Hunter 260 Owasco Lake
I do the very same thing on my 260. It makes things so much easier.
Jun 1, 2004
8,346
.......... Adding a steering wheel seems to have been a factory after thought...........
heh, heh... looks like the mainsheet was a factory after thought also. Tell me the vang can be controlled from behind the wheel and I'll calm down.
-na -NA Anywhere USA
Originally, the big table was designed as another berth to be lowered as was in the fixed keel 270 which both boats the 260 and 270 were introduced at the same time in 1997 for the model year 1998 as I was again involved with those two boats.
There is a term in aviation called crabbing. when flying a straight course from point A to point B with a side wind, pilots would turn the nose slightly into the wind to maintain that straight line. Similar application can be applied to sailing
I have had clients in the past actually take the 26 and 260 to the islands but a lot of preparation and experience were the keys not to mention to stay away during hurricane season.
Nov 8, 2010
11,386
Interesting, thanks for the explanation!
A GREAT idea for low mounted mainsheets is to double end the sheet and add a cleats (each side) in a higher location. This is done very successfully on many types of boats.
The First 260 can be sailed with its traveler removed; when you do this the mainsheet cleats to the cockpit floor and is way too low. Thankfully Beni designed a system that allows bench level cleats on each side to manage the sheet. I bet with a little ingenuity someone could work out a system for the H260.
