Have a 23 O'day on trailer and found the rear port bolt/screw looose. The bulkhead in cabin covers the bottom part and ther is no nut to hold. Was going to grind the plastic/fiberglass to gain access. Noted that the 3 other screw head fasteners were screw heads on each side (a little unusual for sure, not sure if there are male/female fasteners in lieu of bolt/nut combos). Any input would be helpful, I think this is a common problem with this design. Problem is top of cabin flexes when raising lowering mast and this is certianly wearing the area out, want to get tight. Was thinking of adding fasteners/nuts adding split ring lock washers.
Im not sure what you mean by " top of cabin flexes when raising lowering mast", other than there is some movement...
there should be NO movement in the cabin top... there has to be a problem with the compression post.
its either gone, rotted at the end, been replaced with something that is too short, or it was too short when it was originally installed...
the "rear port" you speak of, is this a window or an opening?.. and if so, is the loose bolt it has something structural that is causing other problems?..
what you are trying to describe sounds like a barrel bolt fasteners (google it) with part of it missing...
and I cant see the common relation between the port with a loose screw and the cabintop flexing when raising the mast... is this two separate problems, or is one causing the other?
more information, and clarified a bit will help us help you
