Mast raising Gin Pole for a 22 Macgregor
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Hi TC,
Thanks for the suggestions. Awesome. One question about the baby stays connected to the harness. Could you elaborate on that set up a bit. I have a bit of a concept of the setup, but a pic or a bit more detail on that would be appreciated.
I really liked the idea about the long mast bolt and the yoke. I will put that to use my next trip out.
Again, thanks. Al
Select two anchor points forward and aft of the mast step, usually on the gunwale or side decks, on each side of the boat. (I have seen 2 lifeline stanchion bases on a Precision 21 used for this.) Use stranded SS wire with Nicopress swages or splice some single braid Dyneema lines to a carabiner of your choice to attach to the mount points. Splice the other ends to a welded SS ring. Adjust so that this bridle sets the welded SS ring at the same relative position (fore/aft and height) as your mast step pivot point. (I have also seen this done with line tied to the carabiners and ring.) Then attach baby stay line to the ring, and carabiner of choice at top of baby stay. Baby stay attaches to tangs riveted to side of the mast. They do not need to be too high on the mast, in fact, make them low enough to easily reach up and unfasten the carabiner once the mast is stepped.
Custom setup that will not slack as you raise or lower the mast. Makes it easy peasy!
I have also seen folks attach baby stays between top of gin pole and SS ring. If you affix the gin pole at the mast pivot bolt as outlined above (great idea by the way!) then the gin pole will also pivot in the same place as the mast and the SS rings, so the baby stays on the mast and gin pole will not slack, and will hold the whole shebang straight as an arrow. If I had to routinely lower the mast on the water, say to get under a bridge to get to sailing water, this is how I would do it.
Some people use the vang or mainsheet for the multipart purchase to lift the works. Having a multipart purchase with a cam cleat that grips the line is a great idea, you can partially hoist, and then stop, and go futz with out of alignment turnbuckles to your heart's content, and not worry about the mast coming back down.
Jun 12, 2015
11
Macgregor 22 ft St. Augustine
Thank you so much for the clarification and ideas about the bridle. This helps a lot. Al
Jun 12, 2015
11
Great video showing the postioning of the baby stays
Aw, shucks...
About halfway through the video, there's a shot of the bridle that I use for my baby-stays, kind of like what Brian S is describing.
Joe, This video is very helpful in showing the position of the baby stays and how they work.
Thanks,
Al
Nov 9, 2012
2,500
Aw, shucks...
Looks like this:
Sorry the pic is a bit small, it was a screen shot of the video, and it's cropped down pretty far...
Jun 1, 2004
8,258
At the risk of sounding preachy, the term "baby stay" as used in this discussion is a name given by MacGregor to one of the components of its mast raising system. In the real world, a baby stay is a completely different animal.
First of all, calling it a stay would contradict the accepted definition that athwartship guys are shrouds, fore and aft guys are stays. ... so a the very least they should be called "baby shrouds" or "baby side stays" or "anti sway supports" or "side supports" or.... whatever. I think calling them mast stabilizers is more appropriate because that allows them to be made of anything... wire, rope, webbing, tubing, wood.... etc.
It is also quite unusual for a stay or shroud to not be part of a sailboat's standing rigging. Since the aforementioned mast raising sway inhibiters provide no sailing function per se... calling them stays is a reach.
FYI, a baby stay is a short, fore and aft guy whose fundamental purpose is to help bend the mast by pulling its lower middle section forward. It is not the same as an inner forestay, or a solent rig, which are stays that are designed to carry sails.
Again.... not trying to be critical... just making a clarification.
1,113
Joe is of course right. But everybody refers to them as baby stays ah - humans. I just call them butt savers.
I really really hope the winch on the OP's gin pole is a braking winch...not a trailer winch as he said. Really really.
