Shaft & dripless box -
Jan 2, 2015
35
Beneteau 340 Oceania ventura
Seems like some water droplets are collecting on the shaft and throwing droplets on the hull and the water seems like its starting corrosion on the joint that connects shaft to Trans gear box. Anyone seen this before?
7,383
Can't help you with the seal (don't really need one) but once you get the corrosion cleaned up, try coating everything (except rubber parts) with Fluid Film so small leaks won't cause corrosion.
325
Beneteau 393 Chesapeake Bay
Agree with Maine. I grease mine each year with a little dab from a tube from Volvo for that purpose, but I suppose any good Teflon grease could work. If you are still getting some water on the shaft, the rubber boot may need to be replaced.
Jan 2, 2015
35
How do you grease? open the clamps and apply to the inside? I notice a water hose connects water to that seal joint.... what that for?
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
To grease the shaft seal, I take a small soda straw and insert it between the shaft and seal, then squeeze some grease inside the boot. It doesn't need much.
Worn you launch, you need to "burp" the seal to get water into it. The purpose is to provide some cooling. The tube you are referring to is the inlet (or outlet, depending on how you look at it). The cutlass bearing is the other end of the stream.
Oct 3, 2008
325
What Doug said. Except that I just insert the tip of the grease tube under the lip of the seal while pinching the seal on the sides. Just like the burping action. I do it quickly and only a bit of water comes in. Then I turn the prop shaft by hand to spread around the grease. Takes all of a minute to do.
Jan 6, 2014
35
Oceanis 351 Helsinki
The lifetime of Volvo-Penta black box is around five years and the grease should be added every 200 running hours or once a year.
Nov 24, 2012
586
The life depends on the number of hours and maintenance vs years. I've had 4 B boats over the past 35 years and never had to replace one. The obvious keys are lubrication both grease and water - including burping the seal every time the boat goes in the water (from being on the hard). The straw technique for greasing works great.
Oct 29, 2006
388
Beneteau 381 Olympia, WA
I've also found that I need to "re-burp" mid season might be necessary. During heavy summer use I go thru the following: Water will start collecting under the shaft, I'll get all nervous about failing shaft seal and look at replacing the seal, then I'll remember to burp again and that takes care of it. Before every season I do the greasing and burping but funny how I always get worried seeing that cup of water under the shaft.
reworb
Apr 22, 2011
234
Beneteau 311 Ft Myers Beach
That is a Volvo seal and they need annual greasing..
I've read about the soda straw method but mine does not open up enough to get anything between the lip and the shaft. I burp it every time we use the boat as we keep the boat on a a boat-lift out of the water. I know it's burped because I hear air hissing out then after a few seconds water comes out the bottom, but I just can not get the grease in there.
Nov 24, 2012
586
If you can burp it and water comes out you can insert the straw. Fill up the straw and flatten the straw before inserting.
reworb
Apr 22, 2011
234
Thank you so much that worked. I think the key was flattening one end of the straw first.
Gunni
Mar 16, 2010
5,937
A west systems epoxy syringe works very well for injecting grease into the Volvo shaft seal. Fill the syringe with marine grease, pinch the seal and insert the syringe end, squirt and rotate the shaft to distribute. I store the syringe next to the seal, a full syringe lasts for years.
