My wife and I are looking at Catalina 34's in the Southern California area. This will be our first boat, but I consider myself a semi-handy guy and I'm not afraid to work on things or learn. I plan on learning about diesel engines and other necessary maintenance and repairs. I've done plumbing, electrical, and construction for myself when I was younger and couldn't really afford to pay someone else, and since we're retired, I've got time on my hands, (I'm sure that I'll be sorry I said that...)
A broker gave us a copy of a survey from August 2014 on a 1988.
Survey states it's in "overall good condition", but mentions a dozen things to be addressed, as expected, but a couple things cause me concern:
1. Hollow soundings at the 3rd aft stanchion base port and starboard. Service or repair as necessary to stem further water intrusion.
2. There is a small "Catalina smile" that has not yet separated.
On the Mechanical Survey:
1. There has been a significant ongoing bypass of water below the raw water pump. Monitor the raw water pump for leaking salt water onto the lower portion of the engine.
2. A closed cooling pressure test was conducted to 14 psi for 15 minutes with a 1 psi drop in pressure. Determine significance of the 1 psi pressure drop in the cooling system and repair or service as necessary.
3. Manufacturer rated horsepower is 23 at 3200 rpm. During sea trial the wide open throttle was 2400 rpm as read from the analog tachometers. Determine significance of less than manufacturer rated rpm and service as necessary.
With all that being said, should I continue to pursue this boat or run from it? We still have a few more boats to visit here in Southern California, so it's not the only option.
Also, We've looked at three 34's so far and all have had wet bilges. Every broker has tried to explain "that's just the way they are". I realize the source of the water needs to be determined, but it a dry bilge the white whale of Catalina ownership?
Thanks for any thoughts and suggestions.
