I had a busy day. The mast crutch I built about a thousand miles ago sheared its eye bolts that held it to the rudder pintles on the transom and shattered onto the street as we were going to the boat ramp. Pulled into a parking lot, scratched my head for a minute and came up with this:
Admiral asked if we should just head back home... But after seeing the weather and wind forecast, there was no way we were missing it. And, thanks to Boy Scouts, my lashed on cooler was just as solid as any mast crutch. Here's the new one, with 2 stainless steel 3/8" eye bolts holding on this time. Light bar connects with male/female quick-connects to an extension cord off the trailer lights
Then I got inside and installed up the panels I had been finishing in the garage. The Electrical panel has been there for a year, just sitting in place between the fiberglass and cooler. I got 2 of these, and thumb screws to fit:
I installed them backwards using epoxy putty behind the fiberglass:
so they sit flush in the holes:
I screwed a piano hinge to the bottom on the panel, and the 2 black thumb screws hold it in place:
So quickly - and without tools - I can take out the thumb screws and drop the panel open to access the back of my electrical panel. And before anyone says anything about electrical safety, I couldn't find 10ga red wire when I was starting this install, so there are 2 big thick yellow 10ga wires that I will never confuse for safety-wire-color ground. And I don't see a need to ever have AC power on board, anyways:
Made one for the other side to complete my stereo install that I started a couple weeks ago. And gave one of the extinguishers a permanent home:
Next up is storage next to aft berth
