thru-hull electronics
Oct 8, 2013
18
Hunter 23.5 Toledo
have a Raymarine tridata i50 (depth/speed) to install on my 1995 hunter 23.5
Because it is a water ballast I'm having trouble locating a place to install the thru-hull. The manual does not address the issue, can anyone help?
Thanks Jerry
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Don't think I would put a through hull transducer in that boat. Suggest fishfinder/gps and silicone mount transducer inside the hull. This will provide all the thru hull can,plus much more. Chief
Nov 26, 2012
2,315
He will get a gps speed readout. Close enough unless he is a racing nut! ha Mine never works after a couple weeks in the sea! Chief
May 24, 2004
7,193
CC 30 South Florida
A GPS provides speed over bottom but not speed over water. The difference in readings between the two instruments may vary from nil to very significant depending on the course and the strength and direction of the currents.
Kermit
Jul 31, 2010
5,696
Rather than debate the merits of each kind, he still needs an answer. There should be a place for the transducer shown in the owner's manual. Crazy Dave Condon is the man who knows everything there is to know about water ballast Hunters. Hopefully he'll see this thread and respond.
Oops. Just reread your question. I see the manual doesn't have the answer. Crazy Dave to the rescue!
-na -NA Anywhere USA
Kermit sent me a link to this. The best place to put a thru hull transducer is adjacent to the bilge pump under the rear berth generally to the left of it as you are facing toward the rear on the flattest spot. If thru hull, measure the fitting which generally is close to a 2 inch hole and drill thru. Remove any paint on the outside where the flange of the fitting would go over the hull and sand the gel coat for good adhesion. Liberally apply 5200 on that fitting to include the flange area and push in.. Tighten the collar down as far as it will go without turning the fitting and let the 5200 dry for 7 days. Do clean up the excess 5200 using alcohol. You will need to clean the area inside and wipe down with acetone on the fiberglass. When you turn down the locking collar, put a dab of silicon on the threads, not 5200, to help to hold that collar fast. Make sure the arrow points forward
You could instead clean the area inside first, sand it as smooth as possible and clean again with acetone. Then take plummers putty and a lot of it and immerse that transducer down noting the arrow to show forward and pack the putty around and let stand until it drys. Kermit made me a believer out of that.
As for speed, the GPS is good on that. I always hated to remove the speed transducer to clean it often as you generally cannot place anti fouling paint on top of it but you can on the depth transducer.
I never cared for the fish finder gadget attached to the transom.
Oct 8, 2013
18
Hunter 23.5 Toledo
thru-hull
Thanks everyone for the advice, particularly you Dave. You are a fountain of information.
Jerry
