Hi I always pull my speed paddle wheel and swap with the dummy (blank) plug.
Last season end however I could not stop the dripping and when I went to hand tighten more the WHOLE house rotated! Of course the housing should nicely and securely bedded. So the yard pulled me sooner as water was slowly coming in.
Replace the whole assembly and found it was bedded in RTV silicon. Basically window chalk that is like rubber cement and never hardens. I could peel off with my fingers. So replace with tried and true 5200.
Did make a nice tool I was proud of to loosen the lock nut that is hard to get to with the housing around the depth and speed. Worked great.
Problem Question:
I am aware of the conduit laid through the vessel and thought I could simply pull the new wire through the bow to the nav station, then to the nav station to the helm. WRONG! We found them but they don't budge. Not sure if the depth and speed are wire tied or what. Also the below the steering help is a super tight cohesive bundle also wire tied to the shift throttle cable.
Any then it occurred to me just to use the same wire and spice the new to the existing cable already in place. Same wire count and color code.
Any comment would be appreciated.
Best Regards
Craig
Some shots of the tool to loosen stubborn transducer plastic 6 point nuts. Only used to hand tighten the new one as you can over torque.
Problem Question:
Best Regards
Craig
