Raymarine C80 Chartplotter/radar
Jun 9, 2014
17
Catalina 310 Cranston, RI
The bride and I took our new, to us, C310 on it's first sail up to our club. Halfway there black vertical lines started appearing on the screen. If I zoomed in close they reduced but didn't go away. It is 10 years old and was installed by the original owner, from whom we bought it.
I called Raymarine's tech support and left two messages without response. Is this the normal life expectancy for these units? Where would I look to find someone to service it or install a new one?
Many thanks.
Jack Murray
rukidn
Apr 23, 2012
160
Catalina 310 258 Sandusky, OH
You may want to check with Dan Gerhardt in Colorado. He fixed my Raymarine ST4000 autopilot (now a spare) and my wind instrument as well. If he can't work on yours, he may know someone. Nice guy, great work at a reasonable cost (vs. Raymarine). C250@mydurango.net
Jack, for anything & everything electrical, if there is intermittent operation it almost 99% connections. I'd check those before assuming the board in the unit is faulty. Good luck.
May 6, 2010
472
1984 Oday 39 79 Milwaukee
JK - I have an identical rats nest inside a waterproof box in my boat - what did you replace yours with?
DaveJ
Apr 2, 2013
526
There are many opinions on making terminations, but about the worst thing you can do is put a small wire under a screw and tighten it....real tight. Ring terminals are good for the proper application, but I find that ferrules are very good for small wires when terminated to terminal blocks. I have a small junction box inside the base of my mast that terminates the wind instrument wiring. I dropped my mast this year for maintenance and when I reconnected these wires I used ferrules on the wires in the terminal blocks, then taped the whole box. I found some poor connections on the lighting connections, one of the butt splices actually pulled out when the mast was lowered. I recrimped everything with new connectors and applied heat shrink over the marine splices. Whether its a rats nest in the bilge or a poor connection in the mast, either can fail at the most inopportune time....best to make the proper connections the first time!
(Guess I should look in my bilge to see what mine look like)
Cheers
Nov 18, 2013
171
Catalina 310 Campbell River
I had the same thing on C70 unit found the Circuit board had some Corrosion (salt air) clean the contacts and working again.
