I have a 1987 C-22 that sits in a fresh water slip 4 months out of the year. The cable to the retractable keel was replaced two years ago. As the manual suggests, the keel should remain retracted when not sailing, which I have done. Catalina Direct Tech Support stated that the manual is wrong, and the keel should remain down. The boat is in a man made lake with reduced changes in water depth common all season, thereby suggesting that the keel remain retracted until reaching deeper water. The problem is that when finished sailing yesterday, after retracting the keel, the lock down bolt just spins in place, indicating that the lock down is not working. Can this be corrected without removing the boat from the water? If the lock down is not working, when sailing in heavier winds, would the keel be forced to retract at all? My rudder would retract in heavier winds until I placed a breakaway lock down pin in it.
This is my 3rd season of sailing and any help or suggestions would be greatly appreciated.
