ignition breaker issue
Nov 26, 2008
1,970
Endeavour 42 Cruisin
RC
The breaker on our DC panel for the ignition circuit keeps popping.
It did this 2 years ago and I replaced the 20 amp with a 25 amp and all was well for 2 years.
Now I'm in Nowhereville, Bahamas with no ready source of a new breaker. Thinking of swapping the house breaker switch with the ignition breaker. It is rated at 40 amp trip. Would that be unsafe on the ignition side?
This tripping happens when we're anchoring and raising anchor...with a manual windlass!
It's related to idle speed, happens when shifting in or out of gear. Breaker trips, need to reset and then restart engine. Did it multiple times this morning with a cool engine, which is new. It used to only do it at the end of day and I thought it was heat related.
If the breaker is undersized at 25 amps then proper sizing (40?) should fix it, but if 25 amps is plenty for the ignition circuit, then I'm stumped.
Thnx
Ed
May 24, 2004
7,190
CC 30 South Florida
Not much information. Are you having a problem with the cranking circuit or is the engine just cutting out at idle once it is running? Does the engine rely on an electric fuel pump and/or does it have a heating coil? I would say that not knowing which component might be tripping the breaker it would not be safe for you to go to a 40A breaker. When a diesel engine cuts out at idle it is usually a fuel issue. An electric fuel pump that looses power could explain it. A malfunctioning heating coil could also trip the breaker. Is the alternator working properly? It is also possible that your 25A breaker has weakened and it is being tripped by a normal load but unless you test the circuit and its components I would not use a larger breaker.
11,721
Ed,
Use your clamp meter around the wire coming from the breaker. Let us know what you see for amps when doing all the things you mentioned. If that circuit is exceeding 25-30A we need to figure out of this is normal, and what devices are actually powered by the ignition circuit, or if something has been "tagged on" to that circuit that is pushing the limits.
The wire size will determine how many amp breaker is safe but this could also be a short that happens due to vibration at idle etc.....
Nov 26, 2008
1,970
1985 Perkins 4.154 mechanical fuel pump, no coil, no glow plugs. Balmar 70 amp alt with ARS5 regulator. They seem to be fine.
Its not directly related to starting. It starts fine every time. I have a toggle switch at the helm with a spring loaded button to start. The breaker on the panel somehow cuts out the pedestal circuit.
When this was happening 2 years ago, replacing the breaker fixed the problem...for 2 years. Now its happening again with the replacement breaker.
Nov 26, 2008
1,970
RC
Switch on, buzzer buzzing it draws about 2 amps. Starting the engine very briefly flashes 25 to 26 amps before settling back down to 2 amps
It doesnt quit on me at start up, but at idle, shifting in and out of gear. Until the third time this morning and then it popped right away.
I made the swap and it starts OK and the weak breaker is handling low house loads OK.
I can get to George Town in a few days where there is some parts availability.
Jun 6, 2006
6,990
Well with no heater, glowplugs, or electric fuel pump there is not much that an ignition CB would power except the alternator voltage regulator and engine gages and lamps. A voltage regulator is not going to be drawing 20 amps nor will the engine gages and amps.
I suspect there is a bare wire somewhere shorting out due to vibration. Check the wires from the CB to the pedestal where they cross the engine compartment.
Jun 6, 2006
6,990
2 amps sound right. Check for bare wires near the starter solenoid and along the solenoid control wire from pedestal to solenoid.
May 24, 2004
7,190
CC 30 South Florida
No electric pump, no glow plugs and engine cranks and starts fine. In theory the engine should not cutoff at idle as fuel ignition is not dependent on electricity. The governor does not seem to have the ability to meet a load when engaging the propeller. Check for an electric fuel shutoff switch which could be faulty if the boat is equipped with electric engine shutoff. Your breaker tripping and the engine shutoff problem are due to different but interacting problems.
Jan 4, 2006
7,318
Ed, maybe take this down a notch.
As you've described your engine and CB, it should start with the "ignition circuit' in the OFF position. The starter motor does not normally run through a breaker and I would expect a draw greater than 100 A on initial starting. Run the engine through its paces and all other operations with the "ignition circuit" breaker open.
The only electrical connection I can see with the engine may be if you have an external regulator on the alternator and this depends on how it's wired. Other than that, I don't believe there is any electrical applied to your engine.
Please don't leave us hanging as this is one of the more interesting problems to come though here in quite some time. We anxiously await the next installment
Nov 26, 2008
1,970
The toggle start switch at the helm will not buzz without the breaker on. The breaker and the engine start/stop toggle switch are interconnected.
Fuel cutoff solenoid might be connected to this issue. I have one in the engine room but never used it.
I suspect tho the issue is tied to the start/stop switch
May 24, 2004
7,190
CC 30 South Florida
What do you call the start stop switch? is it the key switch for on and off? This switch just powers the gauges, the starter solenoid and the alternator, once the engine is running it is independent. You have a fuel cutoff solenoid in the engine room but never used it, how do you shut the engine off? Is it installed. Does your key switch in the off position activate the fuel cut off solenoid? Look into that as malfunctioning solenoid could be both tripping the fuse and killing the engine.
Jan 4, 2006
7,318
This start/stop toggle switch intrigues me. As you describe it, it sound like it is there in place of a key ignition switch. Can you confirm ?
I think we've confirmed that your "ignition breaker" is supplying power to your alarms. You don't need alarms to run the engine although it's not the greatest idea around but a short run won't hurt. Please confirm if the engine runs with the "ignition breaker" in the OFF position.
I tell you, fly me down to your boat in the Bahamas, feed, board, and entertain me, and I won't leave until I've repaired your problem. As you can imagine, it's still cold here in Canada.
Keep the info coming.
P.S. Benny's idea of the solenoid STOP is well worth looking into.
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
I just got this from a friend cruising north. It may apply. Mine is tied to a smart regulator and fire extinguisher that won't let me run the engine without turning these breakers on.
I reset the regulator by pulling the four-pin connector off …. Letting it set for a minute…and re-installed.
Wham… everything came back perfectly…. Working
TOM from Balmar…said “you’re a cruiser right ? As the solar panels, and the wind-generators get more efficient, and pump more and more amps into the systems…. The older ARS-5’s don’t know what to do with the higher, and higher voltages seen now days…. “ He tells all the cruisers that call… to “put circuit breakers, or shut off switches in the external power devices…. Shut them off IF your using the motor…. NOT required…. Sailing or at anchor YES… moving under power…. Shut them DOWN… “
SO……………. That’s the first time we’ve ever gotten an “HIV” alarm… So I guess we’ll take his advice..
All U Get
6,243
S2 9.2a Fairhope Al
one sure way to find out is disconnect the external power sources and see if the problem stops happening then you will know
11,721
RC
We need to figure out which wire is drawing the 25-26A. Your starter solenoid should be 10A or less. Now that you know what the CB sees now we need to isolate each wire off that circuit and see what it is drawing. Regulator, solenoid etc. etc... Regulator should be a max of about 7A when full fielded but ideally would never be wired to the ignition circuit for the full regulator load just the brown / ignition wire goes to ignition, which is fractions of an amp......
Does your clamp meter have a "peak hold" function for DC amps?? How long will it stay on before putting itself to sleep...?
Nov 26, 2008
1,970
Another problem yesterday was that the local BTC data signal died. We were 'borrowing' an open wifi that was very weak.
BTC came back on line last night. I was able to do a bit of surfing. My Diesel Kiki fuel pump looks to have an electric shut off solenoid. I wiggled wires but no shut off. I have inquiries into Trans Atlantic for more info on this pump.
The engine will not start or run with the breaker off.
There is no key switch. There is a toggle switch and a plunger. Flip up the toggle switch and the alarms go off. Press the plunger and the engine starts. Flip down the toggle switch and the engine shuts off. All of this in conjunction with the breaker on the DC panel on.
Nov 26, 2008
1,970
More mysteries...
Clamp on meter to input side of wire leading to the circuit breaker, briefly reads 25 to 26 amps.
There are 2 wires coming off the output side. The orange one shows no reading with clamp meter. The red wire shows 11 to 12 amps at startup.
How do I loose 12 amps there?
Nov 26, 2008
1,970
More mysteries
TAD says the fuel pump solenoid draws very little.
Also tells me I do have glow plugs. But I see no wiring anywhere that I would think are for glow plugs. Hmm
"...and the alarms go off..."
Does this mean the sounds from the alarms start or stop?
English is funny this way, some people say that when their fire alarm, for example, goes OFF, it means it is making noise!
Also, what engine do you have?
