Im putting a roller furler on boat and it will have a turnbuckle inside the drum at the bottom.
Since this wont be normally visible for regular inspection, what is the best way to implement some sort of keeper to make sure the turbuckle does not rotate?
I bought the turnbuckle already but it looks like they never come with whatever you need for the keeper.
Is this just the largest staibless steel wire you can find that will fit through the hole on both threaded parts and the wrapped around the turnbuckle..
Or??
Or??
