Hello All,
Looking to hear from owners/ skippers about the stability of a Islander 37 MS in heavy seas, gale conditions ? Yes, I realize that the seamanship of the skipper is always the deciding factor.
I think the Islander 37 hull is the same in both I-37 models, except one is built as a motor sailor on the same hull.
Thanks,
Avery
you have answered your own question in your second sentence.
the islander 37 is an offshore rated boat but with the smaller fin keel and smaller spade rudder and "pilot house", it is NOT a heavy weather boat.
keep in mind that "offshore" rated is NOT the same as "open ocean" rated.
the capsize factor may be within reason, but I would consider the need to be at the helm all the time in moderate to heavy seas to keep the boat on coarse due the the keel and rudder design.
but there are many boats that are much less that have sailed the world without incident, but few of them have ever faced gale or storm conditions.
no one can know the power of a storm at sea, or be mentally or physically prepared for it until they have been thru a couple of severe blows while offshore with a nearly unlimited fetch...
but once you have experienced it enough so you know the power it has, then you will have a better idea of what boat you might want to ride thru the experience in...
the islander 34 is a much differently designed boat than the islander 37ms... the sailing characteristics cant be compared other than the name....
