As any one had a battery selector switch go bad?
When I put my switch on battery one. My stereo unit constantly goes off and on. If I put my volt meter between the switch for the stereo and the ground I can see the volts jumping up and down but if I put the volt meter between the battery cable on the back of the selector switch and the ground it shows good constant volts. The same problem does not occur when I turn the switch to battery two. Doesn't that say the selector switch is bad on the battery one side?
Gary
Gary
